97 F250 LD S/C, interior dome lamps.
I am having a problem with the interior dome lamps stayin on longer than normal. Ihave replaced the drivers door switch. can the CTM(CENTRAL TIMER MODULE)or the GEM(generic electronic module)be bypassed or disconnected.If i remove the fuse or the relay i lose pwr. window functions. any help please contact me at FALLSMEDIC@AOL.COM also. thanks.
Good news!!
I fixed the dome light problem, with the input supplied here.
I sprayed the latch with silicone based lub, and it totally fixed the problem - and now the dome light shuts off right away!!
Thanks Jim Caudill, and everyone else !!
Flailr
98 F150 Supercab,
4x4 package
Totally stock
42K miles
Quote:
The door position switches are physically located on the door latch mechanism. There is a plunger that is spring loaded to ..... these plungers get "sticky" and do not sense the ......
Flailr
98 F150 Supercab,
4x4 package
Totally stock
42K miles
