Now What??
Now What??
I rebuilt the turbo about three months ago. It had lots of play on both sides but had no contact so I went with the stock bearings. Had no choice as I could not get any info on radial play. Was under the hood the other day and found what looks like a leak in the oil seal on the exhaust side of the turbo. Strange thing is I am not getting any smoke out the exhaust. What could this be?
If you right click on the x go to properties and copy and paste the URL in the address bar you can see the pic. Any body know why pics come up as a x? I would really like to be able to post pictures so any help would be appreciated.
Thanks......
Thanks......
I will have to look into that. Seems strange that oil would creep UP that far. And if you take a close look at the pic there is oil on top. Used new O rings when I did the rebuild.
Any body Know what the thread size is on the solenoid. I would like to remove it and plug it with a set screw. Left hand thread?
As for smoke I do seem to get a Little more than usual on start up will go away after warm up GP's checked out OK..
Milwaukee1979F150
02-23-2012 08:50 AM
