Exhaust pipe size
Old 06-03-2008, 09:32 AM
mrpositraction's Avatar
mrpositraction
mrpositraction is offline
Exhaust pipe size
After Catylitic converters and before the Y on a 2007 F150 5.4L truck. I am wanting to cut just before the Y and run a true dual system. I need to know the size of the pipe? I am guessing 2.25" but it could be as big as 2.5".
Thanks,
Old 06-03-2008, 09:44 AM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl is offline
If I recall right its 2.5".
Old 06-03-2008, 10:23 AM
mrpositraction
Nevermind, I found it. It is 2.5" coming out of both cats.
Thanks,
Greg
mrpositraction
Thanks, I didn't refresh my screen before replying. You are correct.
Old 06-03-2008, 11:30 AM
mrpositraction
Well, i am going to build a true dual system with manderel bends using the DIDO.
Old 06-03-2008, 12:38 PM
Sweet.....
Old 06-03-2008, 01:12 PM
mrpositraction
Sweet.....
I hope it uncorks it and it sounds better than it does. I will get pics up when I am done. I just ordered all the parts so they should be here by the end of the week. Called my buddy with the shop and welder and we might even do it this weekend if all goes right.
More to come!
Old 06-03-2008, 03:59 PM
What muffler are you going to use?
Old 06-03-2008, 04:30 PM
mrpositraction
Magnaflow DIDO 18" or 22" muffler, whichever one my local shop can get cheaper at dealer cost. I am torn to have more sound or not, so I will let fate choose my destiny.
Old 06-03-2008, 07:57 PM
Twinsdad98's Avatar
Twinsdad98
Twinsdad98 is offline
Ok, NOW I'm jealous. Let me know how it turns out and I may end up doing the same thing with an X-pipe where the Y is....
Old 06-03-2008, 08:31 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
You can use a magnaflow DIDO with the x pipe in the muffler. It'd be easier to run and cheaper.
The shorter the muffler the louder.
2.5" true duals is almost to big.
2.25" is what I'm runing with a homemade x pipe (thingy ma jig). Flows great, and sounds just as good.
You should be really happy with the sound after you're finished.
Good luck.
Old 06-03-2008, 10:12 PM
mrpositraction
Good luck.
I am running 9#'s of boost behind the ole 5.4L though, she needs all of the 2.5" I have plenty of low end thanks to the positive displacement blower
Old 06-03-2008, 10:14 PM
mrpositraction
Good luck.
That is sort of the line of thought that I had going into this. I started looking at a X-pipe for before the muffler but I am pretty sure the inside of a magnaflow DIDO isn't partitioned and when the packing burns off it will act as an equalizer. Who knows though, if I can find an x-pipe cheap enough I would put one in. I loved how it sounded on my Cobra!
Old 06-04-2008, 02:33 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
the x pipe is litterly 2 pieces of pipe welded together...no partition...I think it's the same one they use on the Mustangs
Old 06-04-2008, 09:19 AM
mrpositraction
It is the same they use on the mustang. The sole reason for an H pipe or an X pipe is to equalize exhaust pressure.
On another note, I found a local shop that would do the install for $159 including the muffler. I have all the bends already and tips so it looks like this is going to cost me $259, not bad.
