Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 05-22-2008, 10:51 AM
IDMooseMan's Avatar
IDMooseMan IDMooseMan is offline
IDMooseMan is gaining momentum as a positive member of FTE.IDMooseMan is gaining momentum as a positive member of FTE.
Talking ICP Resistance Mod Results
The 5/19/2008 Dyno Day at Meridian Motor Sports was my first dyno event and I had a blast.
Don was very helpful with his instructions and suggestions on what to do once on the rollers. The dyno he has in his shop is a DYNOJET. That's all I know about it.
I want to start out by saying: my truck is mostly in stock condition - mods (what little there are) are listed in my signature. I also believe I have some torque converter slippage and am in the process of correcting that. Also, since this was my first time on a dyno, I was a little hesitant with the go-pedal.
Prior to the Dyno Day, I was running the 14.7K combination. My mileage increased to 17.7 MPG. I am now running the 20.3K combination and haven't had a chance to calculate mileage yet. When I filled my tank yesterday, mileage calculated out to 17.02 MPG. This included (about a week or so) running with the 14.7K, then the Dyno Day testing, and switching to the 20.3K combination before filling the tank to start mileage calculation.
The numbers listed below were obtained in the 2100 RPM - 2600 RPM range. I ended the runs between 3000 RPM - 3200 RPM. Like I said, my truck is stock and there was no increase in numbers. The numbers were actually dropping off after 2800 RPMs.
Here are the numbers I produced using the different resistor combinations with my truck:
Stock 137.9 / 310.3 16.5 MPG
4.7K 130.9 / 310.3 N/A
5.6K 142.2 / 334.5 Not calculated
10K 126.1 / 288.5 N/A
14.7K 163.0 / 340.7 17.7 MPG
20.3K 168.7 / 398.4 Not calculated
25K 126.7 / 297.7 N/A
I was having so much fun, I didn't even consider the 15.6K combination. Maybe next time, and there WILL be a next time on the rollers. What this tells me, for my truck, the 20.3K is the best combination at this time. I need to make up additional combinations for the next Dyno Day. Looks like I'll be heading back to Radio Shack for some performance parts.
I expected a numbers drop with the 25K, but notice the drop with the 4.7K and 10K resistors. What this also tells me is...each truck WILL respond differently to the different resistor combinations.
__________________
Craig "IDMooseMan" Peters
1997 F-350 XLT 4x4 Crew Cab Long Bed E4OD 4.10:1, 1991 Wilderness 24M
USAF SSgt 1983 - 1992, NAHC Life Member, Member: NRA and Good Sam
Homedale Rod and Gun Club Membership Committee Chairman, 1/1/2007 - 12/31/2009
To those that have served, Thank You. To those that haven't served, You're Welcome.
  #2 (permalink)
Old 05-22-2008, 11:00 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs has a great reputation on FTE.tjbeggs has a great reputation on FTE.tjbeggs has a great reputation on FTE.tjbeggs has a great reputation on FTE.tjbeggs has a great reputation on FTE.
Very good info! thanks! Tried to rep but I have to spread the love!
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 260K
  #3 (permalink)
Old 05-22-2008, 11:04 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 is a name known to allNeal 97 250 is a name known to allNeal 97 250 is a name known to allNeal 97 250 is a name known to allNeal 97 250 is a name known to allNeal 97 250 is a name known to all
Great info. Reps sent to ya.
__________________
97 F250 7.3PSD X-Cab, SWB, 4X4 5spd, 4.10gears, 3.5” DP, 4” Exh.,BDP 140v IDM,CCV,HPX,6637mods
Rosewood 180cc Stage II's, DP Tuner Live Tuned, Modded H2E, Terminated HPOS, Comp 910's, ARP studs, Swamps Pushrods, 6.oh Cooler, BDP elec. reg. return fuel, Valair full feramic clutch
Neal's Pics and H2E install
Tennessee Chapter Leader Join Chapter here
  #4 (permalink)
Old 05-22-2008, 11:44 AM
Flea's Avatar
Flea Flea is offline
Flea is starting off with a positive reputation.
On that note. I was running a 15.6k the other day on the highway and I got avg about 17.7 mpg.
Also, had problems with truck surging while at highway speeds and later with a hot motor and driving around town. I thought it was the CPS and posted on that issue.
Tach was moving with cranking.
I pulled the whole ICP mod and went to a stock configuration.
Haven't had a problem since.
I think i need to re-crimp my resistors.
Also have had an oil leak at rear pass. side head where HP oil line feeds into head.
Did the increase in oil pressure blow this gasket/ o-ring?
__________________
Fletch
________
'97 PSD 4x4 Supercab, E40D, 3.55, 113K miles,
Waste Veg. Oil conversion - GoldenFuelSystems.com
Tymar Intake,ccv mod, 3" DP,Cat delete, muff delete, Cooner 20K mod, TruCool Max Tranny cooler.
... to come
Aeroforce Terminator gauge (Thanks Tim, I have been looking for an all in one gauge).
Truck Pics
  #5 (permalink)
Old 05-22-2008, 11:48 AM
jimwilsonmasonry's Avatar
jimwilsonmasonry jimwilsonmasonry is offline
jimwilsonmasonry is starting off with a positive reputation.
were the resistors hooked up c00ns way or the other way
__________________
I have a 96 psd with 302k miles,3:55s, cc ,5" stack,e4od-shift kit ,2wd,k&n intake 3" dp, ccv mod,no cat, hotpedal,140v idm,hpx,tw 6 pos chip, gauges,maxi cool xl trans cooler,305x70x16 tires,ported intake---94 trans am lt1 lots of bolt ons
  #6 (permalink)
Old 05-22-2008, 11:50 AM
tjbeggs's Avatar
You may have had a bad connection with the resistors. Thats one downfall to the 10K mod. If your connections aren't perfect it affects the engine performance. On the leak, the pressure could have exposed a weak o-ring but not caused it.
__________________
Tim
  #7 (permalink)
Old 05-22-2008, 11:51 AM
IDMooseMan's Avatar
I should have mentioned this in the original post. My apologies, ladies and gentlemen.
The resistors are connected in-line in the blue/red tracer wire on the ICP.
Sorry for any confusion this may have caused.
__________________
  #8 (permalink)
Old 05-22-2008, 12:14 PM
so you gained 30 hp and about tq with the 20k resistor -nice!!
__________________
  #9 (permalink)
Old 05-22-2008, 12:15 PM
90 tq sorry
__________________
  #10 (permalink)
Old 05-22-2008, 12:43 PM
IDMooseMan's Avatar
Yep. The dyno operator/shop owner was so impressed with what I was doing, he kept asking me if I had more combinations to check.
This was a "special" event by another local diesel truck club I joined. I paid $50 for the first three runs, an additional $30 for the next three runs. The dyno guy was having so much fun watching me shut off the engine, jump out of the truck, unplug one resistor combo, put in a different combo, jump back in the truck, start the engine and make another run. He let keep going at no cost just to watch the HP/TQ numbers change with such a simple modification.
Another event is scheduled for later this year. I hope to have the exhaust, downpipe, gauges, flexplate, TC, and tranny done before the next event so I can check the resistors again.
__________________
  #11 (permalink)
Old 05-22-2008, 02:49 PM
93f1505.0L's Avatar
93f1505.0L 93f1505.0L is offline
93f1505.0L is starting off with a positive reputation.
I had the same problem with my truck about a week after i did the mod, I took it all back out and sodered it all up and havent had a problem sense.
I wish I could find a club around here that did tha kind of thing.
__________________
96 F250 7.3L 4X4 E4OD Ext. Cab.
Intake, Exhaust, Superchip.
6.0L IC, 4wheel disc brakes.
120v IDM, DANA 60 front. Elec. Fuel!!
Waitin on the shelf:
SD HPOP, SD 3" intake plenums
  #12 (permalink)
Old 05-22-2008, 06:41 PM
Flea's Avatar
Yes me too. I would like to see the numbers some time.
__________________
Fletch
________
... to come
Truck Pics
  #13 (permalink)
Old 05-23-2008, 12:45 AM
RubberDuck's Avatar
RubberDuck RubberDuck is offline
DeathRowDiesel Inmate #1
RubberDuck has a great reputation on FTE.RubberDuck has a great reputation on FTE.RubberDuck has a great reputation on FTE.RubberDuck has a great reputation on FTE.RubberDuck has a great reputation on FTE.
Rep sent!!!!!!!!
__________________
RubberDuck
1995 F350 4x4 CC Dually-ROCKEE
1995 F350 4x4 Reg. Cab Dually-Super Street Puller-BOBBIE'S KITCHEN PASS
  #14 (permalink)
Old 05-23-2008, 01:23 PM
IDMooseMan's Avatar
Thanks for the input, reps, and comments everyone. After seeing the numbers on the dyno, I hafta recommend when doing this mod that dyno runs be done.
I was amazed that some resistors actually caused a DECREASE in numbers. I would never have known that if I hadn't been on the rollers and seen it with my own eyes.
Factoring in the cost of the dyno sessions, I think this mod is still an inexpensive way to increase performance. If the 20.3K doesn't increase my MPG, I know I can switch back to the 14.7K to give me more power over stock AND increase my MPG.
Knowledge is a wonderful thing.
__________________
  #15 (permalink)
Old 05-23-2008, 01:57 PM
farmer ford's Avatar
farmer ford farmer ford is offline
farmer ford is starting off with a positive reputation.
must spred the reps i guess so i'll post it here. that is awesome info i was wondering if that is compatible to run with my superchips? or just run the resistors alone? i sure want to go along on the next dyno day! good luck with the next mods.
__________________
1978.5 F250 stndrd
l. b. 4 speed manual
3" lift 315/75/R16 SXT's
lund moonvisor, custom
paint(dodge blue, viper
silver) home made winch
bumper Warn 9000
diamond plate tool box
1995 F350 4 dr l. b.
PS 5 speed manual
superchips 315/75/R16
SXT's 3" lift, tool box
100gal. transfer tank
6637 intake
Tags
156k, 1983, 56k, 73, diesel, f250, ford, icp, install, mod, mods, powerstroke, resistance, resistor, resistors
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive -
Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
