Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 11-19-2002, 07:55 PM
Cubman Cubman is offline
Garage is empty, add now
Cubman is starting off with a positive reputation.
'37 V8-60 block repair
Looking for suggestions on the best way to repair the tin-sided block on my '37 V8-60. It appears that someone attempted silver-solder at one time, then patched it up with some type of epoxy. I am down to a 4 lb. radiator cap, and it's still leaking coolant(from the repair) I need to fix the dam before it lets loose on me!! Any input will be welcome. Thanks in advance...
  #2 (permalink)
Old 11-20-2002, 09:51 PM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
Cubman, if you don't get an answer here, check with the guys at this link - they are the premier flathead guys online. You may have to register with MSN groups to post a question, but it's worth the hassle. One of the guys there even races V860's. Good luck.
[http://groups.msn.com/FordFlathead1932to1953/messageboard.msnw?pgmarket=en-us]
  #3 (permalink)
Old 11-22-2002, 07:46 PM
41Clay's Avatar
41Clay 41Clay is offline
41Clay is starting off with a positive reputation.
__________________
forum guidelines
Tags
60, big, club, ford, motor, specifications, specs, troubleshooting, trucks, v8, v860
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
