Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-14-2002, 11:13 PM
2speed 2speed is offline
Garage is empty, add now
2speed is starting off with a positive reputation.
Chevy valves
I've heard Chevy valves work in the Flatheads, what exactly needs to be done. I know to get 1.5" Exhaust valves, but I heard they are longer and need stems ground, possible spring shims, and do the ford keepers work with them or do you need to get new keepers? They're certainly cheaper.....
  #2 (permalink)
Old 12-18-2002, 12:21 PM
54_5star 54_5star is offline
54_5star is starting off with a positive reputation.
Chevy valves
The keeper grove is a little higher on the stem, so you need to shim the springs a little. They are also a little longer from the keeper groove to the end of the stem, also. This problem might be overcome just by using adjustable lifters, but I'm not positive on that. The Chevy exhaust valves are a good step up in getting rid of that horrible lump under the valve head that the stock valves have. You can go one step further and use the 1.60 exhaust valves with undercut stems ( I don't think they are available in 1.50 dia. ). These are usually sold under the Pro flow/ Race flow names.
  #3 (permalink)
Old 12-19-2002, 10:29 PM
hitmiss1 hitmiss1 is offline
hitmiss1 is starting off with a positive reputation.
Chevy valves
Tags
15, 300, block, chevy, flathead, ford, small, v8, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
