Clutch stuck to flywheel
Best way I have found is to tow the truck, with the engine off and tranny in nuetral. Between 5 and 10 mph push in the clutch and slam the tranny into takeoff gear(1st for a three speed, 2nd for a granny 4 speed) Always works first time every time.
Main reason a clutch gets stuck is that it is glazed. If it sits for a while the resin in the friction plate will bond with the flywheel and pressure plate.
When plan A - starting gear and bumping it around - doesn't work time for plan B.
Pull the inspection cover and get a helper to push the clutch. Use a big screwdriver or similar and a hammer to lightly tap the edge of the disc itself. Just tap it towards the center and slightly away from the flywheel. This has always worked for me when bumping it failed. Once free, drive it around and work the clutch to clean things up.
When plan A - starting gear and bumping it around - doesn't work time for plan B. Pull the inspection cover and get a helper to push the clutch. Use a big screwdriver or similar and a hammer to lightly tap the edge of the disc itself. Just tap it towards the center and slightly away from the flywheel. This has always worked for me when bumping it failed. Once free, drive it around and work the clutch to clean things up.
I bought a dodge in the 80's . Clutch was stuck . Popped it a few times , good to go . Just had a Kubota tractor in the shop . Had to split it . The clutch came out in about 15 pieces ! Story is , it don't always go so smooth ! The tractor only sat 3 months ! Outside , but only 3 months . A bear to split also !
flywheel
here is the best way to unstick it take the dust cover off the bellhousing have a freind push the peddel down get under the truck with a flat skewdriver and a small prybar take the skewdriver insert it under the disk at the flywheel then turn the flywheel with the pry bar and repeat the last step after you turn the flywheel 3 or 4 times it will be free done it on my dent
I have freed many tractors,cars and trucks by JACKING the rear wheels off the ground. This eliminates all the the towing ,can't start or stop,tough on grinding trannys,etc,etc,stuff . Once a vehicles rear wheels are up a few inches off the ground, with safety stands, start her up in gear with the clutch pushed in.Very little pressure on the starting system etc. now that it doesn't have to move an entire truck and no jamming into gear. Rev it up a bit to get the wheels spinning,clutch still depressed,and slam on the brakes. Might take a few slams but this will do the trick and you don't stand a chance of hitting the neighbors mailbox. gary
Bootlegger's Deluxe
12-16-2017 07:34 AM
Poorboy1967
09-07-2016 04:53 PM
