Connect multimedia in dash player to reverse wire in dash on 2006 f150
Old 05-09-2008, 11:23 PM
pep100's Avatar
pep100
pep100 is offline
I have a 2006 f150 SCREW. I just bought a Valor DTS 660w. the 660 has a reverse wire. I have a Audiovox license plate backup camera.
If I can connect the 660 to the trucks reverse wire, the 660 will switch to rear camera automatically when I put the truck in reverse.
The camera is connected to the reverse wire at the hitch harness. It comes on whenever I put the truck in reverse. W/o connecting the 660 reverse wire to the truck reverse wire, I have to do manual switching on the 660.
Does anyone know where the under the dash reverse wire is located?
Thanks.
Old 05-10-2008, 03:52 PM
pep100's Avatar
pep100
pep100 is offline
I am going to run a wire from my hitch wiring (same reverse wire I used for camera), and follow the camera video feed back to the DTS 660w's brown reverse wire. It should work fine. I'll post results.
Old 05-10-2008, 09:07 PM
pep100's Avatar
pep100
pep100 is offline
Worked perfectly!!!
Old 05-11-2008, 02:42 PM
pep100's Avatar
pep100
pep100 is offline
Actually the reverse wire is white/green not brown. the brown wire on the 660 is mute.
tom18287
6.7L Power Stroke Diesel
07-12-2015 05:12 PM
GormGorm
1999 to 2016 Super Duty
09-24-2012 11:24 PM
GrizzlyMan660
2004 - 2008 F150
04-02-2012 09:21 AM
dzaharias7681
2004 - 2008 F150
04-17-2011 08:19 PM
XHunter
09-01-2010 11:29 AM
Quick Reply: Connect multimedia in dash player to reverse wire in dash on 2006 f150
