Wiper Arm removal?
Wiper arms need to be pried off. there is a tang on the arm that needs to be pulled slightly while upward pressure is applied. A custom bent large screw driver does the truck.
The posts are up in there but have no attachment bolts. the entire assembly is held in place buy the top spanner nut. The spanner nut can be removed with a correct tool or buy careful use of a screwdriver.
Now is a good time to purchase a replacement bezel,spanner and leather seal from Carolina classics. Rick makes them so all the vendors carry Ricks part...About 40 bucks and has the correct cut and thickness leather seal.
I made a spanner wrench from a piece of 3/4" steel pipe ground down to two tangs to fit the nut. Copper Type L works too and has a less chance of marring the new chrome.
Garbz
Garbz
Once you remove the wipers arms I recommend attaching some type of string to each bezel pivot shaft and once you remove the bezel nut and push the pivot bolts down inside the cal vent, it allows for a better paint surface and cleaning the recess area easier.
I bought the wiper removal tool from eastwood; its a snap with that tool verse prying with a flat head. Just be sure to hold the wiper arm with one hand and use the tool with the other. Those things fly off with that tool.
Mitch
Mitch
Mitch
Mitch
A variety of tools out that can remove the nut.
Here's one example made by Scott Drake - it is sitting on top of one of the nuts in this picture. Two square nubs protrude downward to grab the notches in the nuts.
This is anodized aluminum but steel ones are also available. Either should work fine. I sort of like the aluminum version to help save the chrome as best as possible.
Here's a link to the web site. I bought mine off of ebay for about half that price.
http://www.drakeautomotivegroup.com/...L.aspx?wid=141
How well does it fit? I can't tell from the photo.
I ground a socket so that it has the two tangs. Very careful use of a bench grinder to achieve that.
I bought a steel one from an Ebay seller a year or two ago and it did not fit well, so I returned it. The outer diameter was larger, which is not necessarily bad but the inner diameter was also quite large so care has to be taken while using it, to prevent it from slipping off.
and the nut is not shown in that drawing that I can see. The nut is a hardware part number
370695-S37 (MM213D)
On the subject of wiper arm removal, this tool is actually very handy, too. You still have to trip the spring clip underneath but this tool takes all of the spring pressure off of the arm so removing and installing the arm on the shaft is much easier - especially aligning it when reinstalling it. This is ANCO tool No. 101 I believe.
salf100
11-11-2014 10:41 PM
oldblue89
12-25-2009 05:20 PM
