new member 1964 f100
Old 07-21-2019, 09:40 AM
Kesselrun's Avatar
Kesselrun
Kesselrun is offline
Hi everybody,I just picked up a 1964 f100 Custom cab 2wd 292. I've been lurking around reading through the back pages gathering info on these trucks. I'm not new to turning wrenches but I am new to old ford trucks. Before I do anything I need to get a service and parts manual, I'm thinking of buying the downloadable manuals and then having the service manual printed out at Staples or Office Depot so that I have a hard copy and one on my computer. Has anyone ever tried this? My first order of business is to find out why the PO couldn't get it to pump fuel to the carb,the tank is leaking and they were trying to pump from a gas can. The pump looks pretty new and there are only so many things that could be wrong. I was thinking of priming from the pump to the carb by pushing gas through with a syringe and taking it from there. It will run when gas is poured directly into the carb. Thanks for the help.
Old 07-21-2019, 10:40 PM
F100 '64's Avatar
F100 '64
F100 '64 is offline
Welcome to the forum. I really like 64's but then I'm a little prejudice. Post a few pictures and your VIN and one of the guys will decode it for you. ~Pat
Old 07-22-2019, 06:09 AM
66v8baby's Avatar
66v8baby
66v8baby is offline
Before you catch your truck on fire, get rid of the leaking tank! Inspect all the lines both steel and rubber. If they're rusted or rotted, replace them at the same time. Once the line is not obstructed and the tank and lines are sealed, fuel should drip steadily from the line at the pump end once suction has been pulled. Make sure your fuel pump is good by running a rubber hose from the pump straight to a gas can. If you don't get good steady flow to the carb, replace the pump.
Welcome to the forum!
Old 07-22-2019, 08:10 AM
Kesselrun's Avatar
Kesselrun
The fuel tank isn't currently hooked up. I had thought about finding a shop to fix it but considering that a new tank is only $200 I'm probably going that route. The PO tried getting it to suck fuel from a can with no luck. I'm thinking that I need to prime it or that the fuel pump was installed incorrectly.
Old 07-22-2019, 10:47 PM
F100 '64's Avatar
F100 '64
F100 '64 is offline
Very nice looking truck. I do like the two tone colors...
Old 07-23-2019, 07:35 PM
john jamieson's Avatar
john jamieson
john jamieson is offline
Check ebay for hard copies for the manuals. Most likely cheaper than having one printed
Old 07-26-2019, 01:05 PM
tripleframe's Avatar
tripleframe
tripleframe is offline
Fuel systems as well as brake systems can be a pain when truck sits for long period of time. Completely go thru both. Nice find. The tu tone paint looks sharp, not as common as the deluxe tu tone. '61-'64 pickups are essentially carryover engineering from the 50's, so you really have an 50's old school ride with 60's styling.
Old 07-26-2019, 02:49 PM
Itsmyford's Avatar
Itsmyford
Itsmyford is offline
FWIW, I just had my behind the tank cleaned and relined for $300 (northeast prices). Just wanted to re-use original. I also like the two tone paint job. This is similar to what I want on my 61. Would appreciate a few more pics.
Old 07-26-2019, 03:39 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
Manuals are available as reprints. So first, make sure having them printed will be cheaper than a reprint.
Another thing is that at least some of the electronic versions (cd, download, etc) have copywrite protection that make it difficult to print or require a key to install. So you'll want to make sure it can be printed and/or decide if you want to use one of a limited number of installs allowed by the key.
Regarding the fuel pump, a really careless mechanic can install it incorrectly so that the arm is in front of the eccentric and gets bent during installation. Another thing is that a small block pump will bolt up but the arm is the wrong shape to work. An FE pump will work so that gives you more options for replacement, if you don't need it to be absolutely correct.
Old 07-31-2019, 07:19 PM
kesselrun1's Avatar
kesselrun1
kesselrun1 is offline
I'll try and post some more pictures when I can. I got the fuel situation sorted out,once I primed it it i got to run. It ran poorly but at least I know it will run on its own. My project now is to redo the fuel system, I should have my new tank tomorrow and I'll fab all new metal lines while I'm at it. I just received a hard copy of the the 64 service manual that Ive already been reading through. I also found the very dry and fragile factory build sheet in the springs under the seat,the vin on the sheet matches my door tag,I'll post a picture of it to get decoded soon.
68F100NY
15
06-24-2015 08:38 PM
StanJo
13
06-12-2014 07:46 AM
jwilly53
05-06-2012 05:30 PM
jabroni1979
10-14-2008 11:39 PM
Ego Flat 48
10-09-2008 09:11 PM
Quick Reply: new member 1964 f100
