loud clicking noise from turn signal switch?
Example, if I'm turning the wheel to the left with the left turn signal on there will be a LOUD click, click, click ect. sound from the column. The sound is louder than the turn signal relay and can be heard with the radio on.
Today is the third time I've brought it in to have fixed and now they tell me it is "normal". They came to the conclusion that it is "normal" because two other trucks on their lot make a noticable clicking sound and one is just as loud as mine. However, My truck JUST STARTED making the noise a few months ago and was quiet when I originally bought it.
I know this is not a big problem ,but it is annoying and I want it fixed. Anyways, my Ford dealer had bailed out on me so how do I fix it myself?
Can you hear the column switch clicking ALOUD in your truck?
Thanks
Rick
Thanks
Rick
I'm pretty sure that it is normal if you are talking about what I think you are. It is the plastic teeth in there that makes it so the turn signal automatically turns off when you straighten the wheel. The teeth have to bend a little bit to get past, and you are hearing them snap back into place. In some vehicles it is louder than in others.
Thanks
I pulled the bottom steering column cover off and from there I was just able to see how it works. There is only a small amount of white grease inside the ratchet part and nothing on the gear.
There looks to be only two screws holding the turn signal switch assembly in place. If I take out those two screws will the switch come out easy or will a dozen springs go flying out?
Thanks for the replies
YES!! I have a 1976 ford f100 and the turn signal did not click back when turning left. My steering wheel was also cracked and in bad shape. So, I purchased a new original steering wheel and new turn signal switch. When I picked my truck up, there was a very noticable loud click when turning the wheel. I asked my mec why and he said it was normal.... I do not like it! It never had the load click before. How do we fix the problem???
RickF350, Please read my reply to your post about load click coming from turn signal switch. With my 76 F100, when I replaced the turn signal switch and the steering wheel, the clicking became very loud. It was quiet as a mouse before I replaced the switch and steering wheel. Can you tell me in more detail what you did to fix the problem??? Driving me krazy!! Thanks, Jack
Hello. I'm having the same problem as Rick350. A very loud clicking when I use the turn signal and turn the steering wheel on my 76 F100. It was not there before replacing the turn signal switch and steering wheel (original). How can i fix this? I asked Rick for more details but no reply so far. If you have any ideas please let me know. Jack
Guys, Rick hasn't posted here since June.
Northernroots122
19
02-01-2024 04:49 PM
jeepfix
1997-2006 Expedition & Navigator
08-22-2015 09:18 AM
hooler1
06-19-2015 10:17 PM
