Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Clicks when turn sharp. CV joint?
Old Mar 8, 2017 | 01:32 PM
accent2010's Avatar
accent2010
Just fixed the bad wheel bearing and a bad ball join on the passenger side. Now the only noise left is the clicks sound when I make sharp turn. Regular turns are normal. CV boots are good. What is wrong?
Old Mar 8, 2017 | 01:46 PM
projectSHO89's Avatar
projectSHO89
Probably the CV joint. Replace the half-shaft, especially if the wheel bearing had failed so that it was "wobbly".
Old Mar 9, 2017 | 05:23 PM
simonsi's Avatar
simonsi
Yep clicking on a sharp turn is CV joint 101 symptom, almost certainly that is what it is.
Old Mar 10, 2017 | 03:22 PM
got2bjoester's Avatar
got2bjoester
Could also be caused by partially unseating the joint while working on the bearing/ball joint.
Either way, replacement of the half shaft is the cure.
mpriester
1997 - 2003 F150
Dec 22, 2010 04:17 PM
gouie
1997 - 2003 F150
May 1, 2009 09:28 PM
Cool1996
Mar 30, 2005 08:05 PM
BOJOFASO
1978 - 1996 Big Bronco
Feb 1, 2004 11:07 PM
