carb. to TBI
carb. to TBI
If the throttle shaft is not worn out, why don't you rebuild it? Ford 2bbls are not that complicated, and if you where contemplating swapping in a complete efi system, I would certainly think you could rebuild a carb with no problems. Just remember, just because it's shown in the exploded view on the rebuild instructions, doesn't mean you have to take it apart. Just take the main sections apart, and use that carb cleaner in a spray can, to squirt through all the little holes and passages.
carb. to TBI
If you can make the problem happen in the driveway where you can work on it, hop out real quick and take the air cleaner off and see if you can figure out what is causing it. Sometimes it can be a solenoid thing that is part of emmissions making it idle high. Sometimes it can be the throttle cable in a bind. Check the return spring too. You can take all this off, and work the carb lever to see if it is wore out.
Binger92
01-22-2011 06:01 PM
Fordication
13
03-10-2004 01:53 PM
