Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-22-2008, 12:06 PM
78bigunns's Avatar
78bigunns is starting off with a positive reputation.
Where could I find a piece o' rubber....?
65' 352.
1" or daimeter tube comes out of valve cover at the rear of the passenger side, bends back and over the back side of the motor, and dumps out near the tranny.
I'm looking for the rubber ring/grommet that fits in the top of the valve cover that this tube slips into.
Tried Advance off the shelf PCV stuff, none are close.
My ride has no PCV system on it (meaning no actual valve and hose leading to the intake somewhere), although I have some valve covers like the ones in this pic that I'd like to restore and put on my 65' that I could use a PCV and do away with my 1" tube.
http://dcregistry.com/users/jays/FordValveCover2.jpg
Then I could tap the carb adaptor and run it there, but for now I'd like to find this grommet to use on my current setup until I restore the other valve covers.
Been searching this morning, but boy is it slow. Lots of valve covers, but haven't found a grommet yet....
__________________
-- Blair --
96' F350 CrewCab 4x4, 351
79' F150 Custom 460 np435 np205 4x4
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-22-2008, 12:48 PM
bertha66's Avatar
bertha66 is starting off with a positive reputation.
I do not thnk that you will find a draft tube that will hook up to the valve covers, the old draft tubes on the FE engines hooked to the back of the intake, there was a about
1" hole that a extended pug pushed into that had a pipe that ran down by the back of the engine. Later FE's had a plug with a nipple there that had a hose attached to a PCV and then ran to the base of the carb.
__________________
Allen D
1966 F-100 4x4 with 67 Fairlane GT 390 and Toyota power steering
1990 Areostar 2wd XLT ext
1991 Areostar 4wd XLT ext
1967 F-100 2wd with auto trans(now for parts)
1980 Bronco with 460
1968 F-350 exforest servive crew truck
1964 Galaxie 500 with 428
  #3 (permalink)
Old 04-22-2008, 03:43 PM
Freightrain's Avatar
Freightrain is gaining momentum as a positive member of FTE.
Only chance to find the actual part is going to Resto parts catalogs(Like AutoKrafters, or the like) as they might actually have a repop of that particular grommet. Other then that...I'd just put a PCV valve in and forget it.
__________________
1967 F100 352/4spd
1969 F100 428CJ/4 spd
64 Galaxie with blown 390 4 spd
64 Galaxie wagon with 428 5 spd
2006 UMTR POWERSHIFT
POINTS CHAMPION
  #4 (permalink)
Old 04-22-2008, 03:53 PM
Alvin in AZ is starting off with a positive reputation.
What I did was put a rubber grommet in the valve cover and a 3/4" plastic elbow and screw type hose clamped a hunk of 3/4" black heater hose to it, did that to each of my valve covers.
One grommet was for a new sealed-up type oil filler cap and the other goes straight into the valve cover. I cut a grove into the "direct into the valve cover" grommet so the hose would lay down there nice and flat.
Motor-Mite "Help!" numbers...
42322 grommet
42324 other;) grommet
47043 3/4" elbow
Sorry, don't have the cap number off hand. :/
BTW be prepared to be jumped and run down by others for not having a PVC system. ;)
Alvin in AZ
  #5 (permalink)
Old 04-22-2008, 03:57 PM
FFR428's Avatar
FFR428 is gaining momentum as a positive member of FTE.
Below the road draft tube in the intake there was a metal breather basket filled with a steel wool type filler. The basket has a lip and it's held by the machined lip in the rear of the intake. Like the guys said the PCV is a mucho better setup than the road draft tube and basket. If your dead set on the road draft tube there are aftermarket's made most Galaxie part vendors sell. HP trends has a really slick billet breather basket for $50.
Ford FE Tri Power Systems by HP Trends
__________________
68 Mercury Cougar XR7. Sumthin FE under da hood.
  #6 (permalink)
Old 04-22-2008, 08:18 PM
78bigunns's Avatar
Thanks for all the replies.
Not set on it at all, just thought it would be easiest.
The fixer upper valve covers have the provision for PCV, so maybe I'll go that route.
Didn't know it was called a road draft tube either..........
For the record, my motor is a 65', and it never had the thing in the rear of the intake.
Mine is off the valve cover. But of course this is on a car, not a truck, so maybe a difference there?
Thanks to all.
__________________
-- Blair --
  #7 (permalink)
Old 04-22-2008, 10:52 PM
As long as it pulled some vacuum out of motor, it doesn't really matter where it comes from. Like mentioned, most early FE's had a plate in rear/center of intake with tube bolted to it. Not sure what year they switched to PVC?
The worst part is if you have a worn engine..it will slobber oil all over everything under the car. Makes for a nice rust free enviroment...but not a clean one!
__________________
1967 F100 352/4spd
POINTS CHAMPION
  #8 (permalink)
Old 04-23-2008, 01:31 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
There's no such thing as a road draft tube off a valve cover, it's some PO's Mickey Mouse arrangement.
The grommet in the right valve cover is there for one reason: to retain the smog valve.
The grommet and smog valve are the same for cars 1965/71 & trucks 1965/76.
The grommet is still available from Ford, as is the smog valve.
PCV system first installed on cars and F100/350's on 1961 CA vehicles. By 1965, the system was used nationwide on all vehicles & engines.
DoAZ6A666A .. Smog Valve ~ Fits 1965/76 F100/350 / 1965/71 cars.
MSRP: $7.13 / ftepartsguy.com price: $3.85
DoAZ6A892C .. Grommet-Smog Valve to Valve Cover ~ Fits 1965/76 F100/350 & 1965/71 cars.
MSRP: $7.11 / ftepartsguy.com price: $5.12
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #9 (permalink)
Old 04-23-2008, 12:32 PM
78bigunns's Avatar
Bill you are the man.
It looks so stock, and with the old grommet, it looked perfectly stock.
Too odd.
Thanks for the parts numbers!!!!
__________________
-- Blair --
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
