Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
  #1 (permalink)
Old 04-21-2008, 06:57 PM
seahawks70s seahawks70s is offline
Garage is empty, add now
seahawks70s is starting off with a positive reputation.
harmonic balancer removel
Is the bolt on a 2.3L motor(95 Ranger) reverse thread? How do you remove the bolt without turning the whole pulley as well.Any help please!
  #2 (permalink)
Old 04-21-2008, 07:03 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
2007 Ford F-250
My Garage
MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.MisterCMK has a spectacular reputation.
An impact wrench is the easiest way to get the bolt off. If an impact wrench is not available, try having someone put the vehicle in gear and stand on the brakes while you loosen the bolt.
__________________
Chris - Avid Winter Hater
2007 F-250 XLT 4x4 CC SB 6.0 PSD - ARP, IPR GEn2 EGR Delete, 4" turbo-back, no muffler, no cat, 6.4 banjo bolts, SCT X3, Tenney 270A alt, coolant filter, air bags, Ranchos, etc.
1994 Mustang GT - HCI, MM suspension parts, etc Novi2k waiting on the shelf
Hope & A Prayer Motorsports
  #3 (permalink)
Old 04-21-2008, 10:16 PM
Bikeitswift Bikeitswift is offline
Bikeitswift is starting off with a positive reputation.
On some other cars, some use deep socket, a long breaker bar to the ground, then bump the starter...make sure your rotation of the engine will loosen it!
__________________
At the Lake
  #4 (permalink)
Old 04-21-2008, 11:20 PM
Thanks for the help Im going to try these ideas just need to know if the bolt threads to the left or the right.I know the motor rotates clock wise,does the bolt thread the same way.Thanks for the help,this is my first timing belt change and its giving me hell.
  #5 (permalink)
Old 04-22-2008, 01:51 AM
MisterCMK's Avatar
2007 Ford F-250
My Garage
It should be a standard fastener.
__________________
  #6 (permalink)
Old 04-25-2008, 05:19 PM
randy6800 randy6800 is offline
randy6800 is starting off with a positive reputation.
i am in the middle of my 96 2.3 timing belt job now, my Ingersol Rand 1/2 inch gun wouldnt take the bolt out, so i took a breaker bar and put on the frame and turned the motor over and it came loose, and i needed a puller to remove the balancer. I replaced the tensioner also, when i would put pressure on the belt it would keep jumping a tooth off on the crank, but i finally got it all lined up.
  #7 (permalink)
Old 04-04-2011, 04:38 PM
redneck1986 redneck1986 is offline
redneck1986 is starting off with a positive reputation.
what kind of gear puller did you use im trying to get mine off my 95 right now and cant seem to doit? was it a claw type or what? my balancer only has 2 holes that are right next to eachother so i cant use the kind that just screws bolts into it and pulls it off and i have no idea how to get the balancer off.
  #8 (permalink)
Old 04-04-2011, 06:49 PM
I used a cheap claw puller and it came off easy. The bolt you turn on the claw puller just sets againt the crank bolt hole, it wont hurt it.
  #9 (permalink)
Old 04-04-2011, 08:31 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to allRogue_Wulff is a name known to all
Take washer off bolt and thread it back in the end of the crank. Takes a few extra seconds, but it's way less time than trying to fix the threads inside the crank cause the puller messed them up.
__________________
1980 F-150 300 I6, C6 & 9" rearend. The workhorse. 300K+
1974 F100 Ranger XLT 390, C6 3.25 axle. Dad bought it new, drove it over 500K. Now that he can no longer drive it came to me. Value: Priceless.
1983 Mazda RX7 1.1L Rotary. The show/autocross/toy. 231K
1995 Mazda B2300 (undercover Ford)
Tags
1994, 2005, 23, 96, b2300, balancer, changing, explorer, ford, harmonic, mazda, puller, ranger, removal, steps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
