Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-20-2008, 10:52 PM
bwilliams7527 is starting off with a positive reputation.
ID a 390?
I'll be heading to PullaPart soon to yank a 390 for rebuild by the machine shop. What ways can I identify a 390 from any other FE? Is there anything specific that will set a 390 apart from 360 or 352? Thanks in advance for any help.
  #2 (permalink)
Old 04-20-2008, 11:43 PM
Putt's Avatar
Putt is starting off with a positive reputation.
Unfortunately, no. There is no external way to tell a 352 from a 360 from a 390. If you can take the time it is possible to check the stroke by using short rod, dowel, wire, etc. to find the stroke length. That will separate the 352/360(3.5" stroke) from the 390(3.78" stroke). I have a 428 presently that has 352 cast into the drivers side front cylinder bank!! Check out the FE engine forum down the page a ways, there have been many discussions about ID tips.
__________________
Putt
1966 F100 4X2 428 4 and 3 sp. 2.75:1 rear
1989 F250 Super cab 351 4X4
1965 Mustang coupe w/289 2bl.
  #3 (permalink)
Old 04-21-2008, 12:15 AM
camperspecial65 is gaining momentum as a positive member of FTE.
Putt, ALL FE blocks began life as a 352...they got punched to their finished bore thus the different engine size...ND made a comment to a thread on this topic a few days ago as I had too..
- cs65
  #4 (permalink)
Old 04-21-2008, 02:28 AM
masterqi is starting off with a positive reputation.
Thus the justified skepticism when anyone tries to sell a 390.
  #5 (permalink)
Old 04-21-2008, 07:50 AM
jowilker has a very good reputation on FTE. jowilker has a very good reputation on FTE. jowilker has a very good reputation on FTE.
cs65, I believe if you will go and research that you will find it not to be so. While all FEs are the same on the outside as noted, they aren't all poured from the same mold and drilled out to size. The 428 starts out very different from the 352. There are darn few 352s that could be bored out to 428.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #6 (permalink)
Old 04-21-2008, 08:01 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
Quote:
Originally Posted by camperspecial65 View Post
Putt, ALL FE blocks began life as a 352...they got punched to their finished bore thus the different engine size...ND made a comment to a thread on this topic a few days ago as I had too..- cs65
Not all FE blocks = only 352/360/390's.
406/427 are different as are 410/428's.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
