no throttle response
I have a 2000 PSD F250 and this morning I was pulling into a local grocery store and when I pushed on the throttle the service engine soon light came on and there was no throttle response. The truck will run and will move forward while in gear at an idle but when pushing the throttle there is no response. I have been told that the throttle control sensor is bad. What I am needing to know is that a stealership item or can a guy get it at a local parts shop. Also is there another sensor under the hood or is there just the one on the throttle pedal. Thanks for the information and all the help you guys have given me.
Is anything else not working? Looking at a fuse diagram, not sure what year it is, but it shows fuse #28 to control the sensor. I would check that fuse or if you have your owners manual you could find which fuse it is there. I will look at mine if no one corrects me on this.
It showing the fuses being under the dash.
Good luck.
Good luck.
Everything works right and the truck runs well but there is no response to the throttle and the service engine soon light comes on only when I push the throttle down. After letting off of the throttle the light goes. I looked for a fuse and found what I thought to be the right one but I believe the number was 19 dont know if I was reading it right or not. If that was the right one it was not blown.
ajorn
06-03-2013 02:04 PM
