1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Deactivated Fobs
Old 04-14-2008, 11:02 PM
kprue's Avatar
kprue
kprue is offline
Deactivated Fobs
I managed to deactivate my key fobs trying to program my keypad, now all I get is the alarm going off anytime I try and do anything. I have tried cycling the key to reprogram my fobs but the alarm is going off the whole time and I can't do anything. How can I reprogram my fobs and stop the damn alarm from going off?
Thanks
Old 04-15-2008, 01:16 AM
ReAX's Avatar
ReAX
ReAX is offline
Sounds odd, you need to get into programming mode and set all of your remotes at the same time.
There was an issue with years on the key pads, model/year might help the diagnosis.
Old 04-15-2008, 01:16 PM
brian97cobra's Avatar
brian97cobra
brian97cobra is offline
cycle ignition switch on/off 8 times. on the 8th cycle leave it on. the door locks will cycle up/down. hit the unlock button on all the remotes you have(not at ones but within a few seconds of each other). turn ignition switch off. remotes are now programed
Old 04-15-2008, 01:24 PM
bpounds's Avatar
bpounds
bpounds is online now
What alarm? Ford FOBS? Or A/M? Kind of depends on who's hardware we are working with, no?
Bill
Old 04-15-2008, 02:03 PM
kprue's Avatar
kprue
kprue is offline
It the Bosch system that Ford installs. Mine is a 2003 F250SD, I have found the valet switch so can now get the truck started and shut of the alarm which the neighbors appreciate. However I am unable to get into programming mode while in valet or bypass mode. I thought I read somewhere that you can hold down the valet button and cycle the ignition but this hasn't worked for me yet. Thanks,
Kent
Old 04-15-2008, 02:32 PM
ccerniglia's Avatar
ccerniglia
ccerniglia is offline
Kent
Ford does NOT use Bosch, its made by "Code systems." If you post a picture of your FOB i can Verify. Its possible whom ever insalled this system may have used an aftermarket setup and led you to believe otherwise.
Old 04-16-2008, 09:46 PM
kprue's Avatar
kprue
kprue is offline
Unable to post picture but it says Ford Motor Company right on the sticker and Bosch underneath that. Alrm&lk system 2c7t-15k602-al
Old 04-17-2008, 07:26 PM
brian97cobra
i explained how to reprogram the remotes.....
unless you do not have a factory remote then i have no clue.
Old 04-17-2008, 07:27 PM
brian97cobra
post a picture of the remote that you have please
thanks
brian
Diane L W
2017+ Super Duty
03-13-2017 10:40 AM
donjamer
General Automotive Discussion
11-01-2015 07:14 AM
Calixto
1997 - 2003 F150
11-09-2014 01:09 AM
selmerSA80
1997-2006 Expedition & Navigator
07-17-2014 08:41 PM
Quick Reply: Deactivated Fobs
