You laugh...but Ford dabbled with that very idea a couple of years ago. They used the A/C lines to cool a reservoir that was pumped through a water to air heat exchanger at WOT, then recovered to the same tank to be used again. Supposedly the recovery time was less than 5 minutes and was worth an additional 50HP over just the intercooler on a superchaged 5.4 Lightning test motor.
No joke??? I've been wanting to do a water to air setup anyway, and that could be a great further mod on that.
Imagine- intake temps below ambient...
Do you think it would have that much benefit on our engines?
What would you do for the A/C? Re-route from cab, or extra???
So if i cooled My coolant by radiator, then by AC, How many BTU's should i look for???
How hard would it be to make The A/C kick out a variable amount based on EGT's?
Sorry for the , but hopefully this can help you too!
444dieselrod, thanks for that explanation. How much is a Nitrous kit and how expensive is it to run? Do you run it all the time or just when you need it? When you need a refill, where on the road can you get it? I'm looking into a DP tune and when I get back home at the end of May I'll try to find my 1.15 houseing. Its buried in my garage somewhere, I think?! Thanks again to you all, Glenn
well, ona non-intercooled, wouldnt it help if you just routed auxilliary lines from ac to intake pipe? would it make much EGT diff? summertime i'm windows down anyway.
Where do you get it for $400? I've been looking around and its $600 to $1,200.
I might be wrong. I just pulled that number off the top of my head. Search Zex on ebay and you will see lots of products. Don't know what will and what won't work but thats whats out there.
What happens if you combine nitrous and propane, do you go boom?!?!
the propane is more likely to do that than nos, with propane you using a flammable gas which makes timing erratic
nos is just an oxidizer just more air is all it is you put too much nos in it just puts out the fire. i want the boost controlled 2 stage i wont need it when the new motor with compunds go in though
Jake, side note here, I finaly passed you in truck miles. 282,688 on the '97
ok sorry, back to the HP.
Diesel Rod
That's OK, I don't mine. Interesting stuff. I assume Rod that you can turn it on (nitrous) and turn it off at will. In other words, use it when you need it. Wife and I travel all over the place, except for welding shops, where else can you get the bottle filled up and how big of bottles do they sell? Glenn
