fuel leak, Valley full of fuel
01-27-2009, 06:24 AM
on
Quote:
Originally Posted by
Cuda_jim
Yep, you got air in it, Keep cranking it. The air will purge eventually. Be sure to give the starter a little time to cool off between cranking.
Well... 5 min. of cranking over the past few days...
and no hint of combustion... Any other options?
note to self: FILL Filter Bowl next time)
01-27-2009, 06:54 AM
Check all fuses?
#22 under hood may have popped when you changed the filter. Fuel heater Shorted out?
Is the tach moving while cranking? CPS issue.
01-27-2009, 01:34 PM
Millwoodva
Are your batteries charged?. Its very important because this motors require a lot of battery power.
01-27-2009, 01:36 PM
also check the level of the HPOP reservoir.
01-27-2009, 02:00 PM
on
RÖENTGEEP
Sorry..Where is that located....?
01-27-2009, 03:27 PM
on
Top front engine. I'm sorry don't have a pict. It takes an allen wrench to remove the plug. Oil should be about 1/2 inch from the top. Edit. found a pict
HPOP Res pictures from trucks photos on webshots
Keep the batteries charged and the starter cool and she should fire.
01-27-2009, 03:55 PM
on
Try to fill the HPOP to the top. You need at least 10.5 volts for the IDM to fire the injectors,remember this if after heating glow plugs. Gotta be sure the batteries are full charged.
01-29-2009, 07:50 AM
on
Took "alls" advise...
Batteries charged to 100 %
All fuses checked - none blown
Topped off HPOP reservoir...took 4oz.
Still cranked... w/o firing....
Unplugged / replugged all related connections..
Fired right up...
01-29-2009, 08:42 AM
Millwoodva
Fired right up...
Glad to hear that. moral= always look for bad connections.
02-01-2009, 11:20 AM
on
Thanks Guys....!
50 miles on it...
valley's dry.. guess it was the "weep" hole.
Thanks again.
ak-angler
Modular V10 (6.8l)
302
11-25-2023 02:39 AM
fmc400
41
09-29-2023 09:46 AM
quaddriver
07-13-2023 08:19 AM
1974 f100
17
05-19-2017 07:05 AM
jacob_powerhouse
09-22-2016 08:58 PM
