89 Crown Vic
89 Crown Vic
Gents,
I have a 1989 Crown Victoria sitting in my pasture. She runs and drives great--but has 219K miles on her and spent most of her life in Ontario. No US registration and leaves a trail of rust everywhere she goes. I didn't spend a lot for her--and am considering plucking her for the buildup of my wife's 51 F1. What should I take? Right now the truck has a running flathead V8, but the wife is torn between loving the sound and the look and a need for A/C in the Texas heat.
Jim
Jim
on
1 Post
I'd use it all!! I dont know how to find post real well? But maybe someone will post the link to the thread of frame swaps and such? I dont want to type all that again, but the frame could be used complete or just stubed? Your choice? If you use the whole frame, you have to shorten the wheel base and then you have to narrow the frame rails. After you've shortend the frame you can cut a hole in the front stubs and the rear stubs and put in a piece of 2x4 rectangle tubing at the heighth you want the cab to sit at. Then you can make the cab mounts and bed mounts. The one big downside of doing this is you loose a considerable amount of bed space due to the way the rear of the frame kicks up? You might just want to use the front?
Also you can get a diagram of the original Ford wiring and do away with all the unnecessary evils of hippy tree hugging pollution junk and use the whole wiring harness too. Keep the EFI and all. Use the seats and everything you can!!! These old Ford engines are great!! The more you use the cheaper it is to build!! Of course this all depends on your welding and fabricating skills.
Most of all have fun, it's supposed to be a hobby and for fun. Enjoy it!!!
90 Crown Vic
I used the power train (motor, tranny) from my 90 CV donor to install in my 50 F1; originally used the steering wheel, but changed to "hybrid" with original steering wheel. I saved everything from the CV, power windows, AC etc but not installing in my build. I am using original CV wiring harness, minus the accessories and EGR. I am running MII IFS; Explorer 8.8. Some pictures in my gallery.
Later
Tom
Later
Tom
I have heard of these swaps before and I think that a member of grandmarq.net was contemplating the same swap. The only problem that I see with this swap is that you have to stick with stock suspension parts for a box Crown Vic (1979-1991). There seems to be little to no aftermarket performance upgrades for these vehicles. I have been modifying my mom's '86 Crown Vic for over a year and it is a difficult task. As of now I am grinding some racing coil springs (to fit the spring isolators) for my mom's car because her stock springs are dead and I don't like the ride height of the stock PI or civilian car springs. You may be better off saving up for a Mustang II front end as there are more upgrades and parts availability for that suspension. Though, the frame is free (you already got it) and those cars share the same motors as the fox body Mustangs (just a different set-up), so I guess that would be a hard decision. In any event, I would love see some pics of your completed work and good luck with whatever path you choose for this project.
Chickenbone
Chickenbone
Hi and Welcome Jim.
First off you can not replace that wonderful flathead sound. Now I am not an expert on AC but why is a flathead motor and AC not a possibility? It would be a lot easier to fab some brackets for the compressor than to rip the flatmotor out and replace it with the crown vic stuff. Save the CV for a truck that is missing its running gear. If you turn a drivable truck into a project and it is not done in short order is your wife going to be happy? You said it was her truck.
Chris
Chris
I'm using the front frame clip from a 87 Town Car, which is the same thing. I have only driven it up and down my 1/4 mile road so far (still waiting on the windshield) but I believe it will be a great suspension. This is not for the faint of heart, I wouldn't have cut up a good frame for it, but the PO had already butchered mine in a failed Volare swap. I am also using the 8.8 rear-end from the Lincoln, mounted on 88 Ranger springs.
on
Gents,
Jim
Jim
