You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
My luck has changed from bad to worse!! While pulling into my drive this afternoon it felt like I just lost my power steering pump, a quick check under the hood revealed that I was leaking coolant all over the place and it must have gotten the belt slick enough to slip. I thought I may have blown a hose or something but after pulling my trucl into my shop I crawled underneath to see where the leak was and couldn't see anything. I sqeezed the lower radiator hose a couple times and the coolant started flowing from just behind the harmonic balancer.............Anyone know what is going on?
Mike
2001 F-250 SD 4x4, 7.3 ltr Turbo Diesel
Bright Amber and Bone Stock
Can you get yourself twisted around underneath there to see the weep hole on the water pump? That's what it sounds like.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
The fan is reverse threaded onto the water pump snout. You'll need to go rent the removal tool from the parts place.
__________________
Scott
__________________
Scott
__________________
Scott
My wife has drill weekend, so I have all the stuff I need but I haven't had the chance to do anything because of the little ones. My dad is going to stop by this afternoon and watch the kids for me so hopefully I will be able to get it fix before the morning.
Do ya have everything , the waterpump , new thermostat, rental wrenches, it's also a good time to change the top rad hose to the one that goes around the belt . If you need anything just call ( I'll pm my cell #)I will be at church this morning till about noon then I'll be fart'n around the shop probably the rest of the day.
__________________
Dave
1999.5 F350 XLT,cc,drw,4X4,a pair of levers,4:10 LS
6637 mod, 4"MBRP cool duals,2 pos chip, ss hpx,ITP pre-pump with holley red pump ,140 V IDM , WW, EBPV deleted,AIH deleted, Autometer gauges
I forgot to pick up a new thermostat......I'll have the wife bring one home when she gets done on the base. I may have to call ya a little later if I get in trouble, done a lot of wrenching on mustangs but never a big diesel.
