works great. helped me get unstuck once and helped my firend change his tire after i got him unstuck. only down fall is if ur not on hard surface u really need something to go under it.
Place the tire iron into the holder with the end that goes over the nut pointing up. this should place the tire iron next to the finder well. Next screw the jack all the way down. Place the top of the jack pointing toward the cab and the yellow screw end pointing down toward the tire and the bottom of the jack will fit into the slot that is in the fender well.
WHAT! The jack can fit under the hood?? Mines behind the rear seat, rattles like he**.....makes it easy to find tho . The tire iron comes in handy too when I have to travel through the inner city (Detroit).
