Gauge Cluster Swap
Best bet would be to check out the wire pinouts via a shop manual. You could always de pin the connector to make things match. Every year has distinct differences usually. For a really small fee, you can view the shop manual and wiring diagrams for any Ford back to '96 electronically on motorcraft technical resources. 72hour subs is $10. Might try that...
Go to motorcraft.com. On the upper toolbar will be a 'technical resources' tab. Click it and you will then navigate away from the main motorcraft page. You will need to sign up and create an account. From there, select which vehicle(s) you want information on. They will give you access to any manual whether it be a vacuum booklet, to the full shop manual, to the wiring pinouts, ground locations, Oasis access, TSBs, everything a trained Ford technician has access to.
*I am not affiliated to motorcraft.com, helm inc, or Ford tech resources. I'm just a happy customer...
Good luck, and let me know if you need any help!
