Supercharged V10
Heres a link to a thread with some info.
https://www.ford-trucks.com/forums/7...ercharger.html
As far as I know the only SC availible for the 2V V10 is centrifical unit from Vortech. Paxton may make a kit but I'm not shure.
The roots or twin screw superchargers such as the Kenne Belle and Whipple units have been discontinued a while back and are the best units.
Most guys run 6-8lbs of boost and get well over 100rwhp and 100 rwtq with the Whipple or Kenne Belle units.
Originally Posted by OverEngineer
What killed the twin screw production
My Kb does 6 to 7 psi, the gains are ridiculous, if you run into problems though you cant just take it to the dealer, they wont be able to help so you end up having to find a tuner you trust and listen to his advise.
If i could do it over again i would do a custom turbo set up. proable try to mount one right around the factory y pipe make all custom plumbing, run a KB boost a pump 36lb injectors, and a piggy back tune. and shoot for 6 to 10 psi. it would prable cost about as much as a used supercharger. plus you dont really now the condition of the SC until you see it in person.
that's my 2 cents.
housedad
11-30-2011 08:27 PM
10, 10ford, 1999, 2001, 68, 68l, f250, ford, screw, snorkle, supercharge, supercharged, supercharger, twin, v10
