Foam Prefilter for my truck
Old 03-25-2008, 02:53 PM
79f100six's Avatar
79f100six
79f100six is offline
I have been watching some tv and seen some of the mud runner trucks that are carburated and they have a foam filter that goes around the regular air filter. I tried looking on the internet and couldnt find anything i was wondering if anyone knew what they are called or where you can buy them. My truck is a 78 with a 400.
Old 03-27-2008, 11:09 AM
kens64's Avatar
kens64
kens64 is offline
Summitracing has them. K&N sells them also. I used to run some of that eggcrate foam during the dusty season and it worked well. Cheap and easy to get.
Old 04-07-2008, 05:24 PM
ReAX's Avatar
ReAX
ReAX is offline
K&N makes two kinds of pre-filters. Airforce 1 which is a red open cell foam similar to what Truflow uses as a primary filter and then they have a pre-screen which is pretty much pantyhose that you slip of the filter.
Old 04-08-2008, 01:01 AM
79f100six's Avatar
79f100six
I looked at summit and i was looking at the k&n foam filter and that pantyhose slip on thing. I was thinking since i have a 4 inch paper filter right now i was going to get the summit 6 inch cotton filter which looks like a k&n just cheaper then get the foam and pantyhose filter things and put both on and the extra 2 inches would make up for restriction even though the foam filter and pantyhose thing only restrict airflow about 2% each, and so when i go mudding i wont have to really worry about getting water or mud clogging up the filter.
Old 04-08-2008, 11:29 AM
ReAX's Avatar
ReAX
ReAX is offline
The pantyhose is more for dusty conditions and does it's best work while touching the cotton gauze filters because of the tiny amount of oil it steals. The oil on the pantyhose acts like the filter. The open cell foam is more for the mud environment, it catches and slows larger particles. If you want to try both, I wouldn't stop you, but the open cell is more for your application.
1970f100guy
04-23-2017 06:31 AM
troverman
6.7L Power Stroke Diesel
15
02-12-2016 11:32 PM
Dorsai
11-24-2014 08:06 PM
doczenith1
06-20-2014 10:15 PM
84 f250 6.9
49
03-29-2009 03:27 AM
Quick Reply: Foam Prefilter for my truck
