Bench seat repair question
So the years of Oklahoma sun, heat, and grandpa *** have pretty much done my bench seat in. I don't think the seat frame itself has problems, but the vinyl is shot and the seat foam is showing some damage as well. In addition, the foam in the backrest is having problems too; there is a fine layer of orange dust on everything behind the seat, from the disintegrating foam.
I'm working with the good folks at SMS Auto Fabrics to get the proper pattern of vinyl for my seat. What I am wondering about is the foam itself...I see that places like LMC Truck and NPD have replacement seat cushions for $250+. I haven't seen replacement foam for the seat back. My question is, do I need to source replacement foam designed specifically for my truck? Or will any competent upholstery shop be able to provide foam that is comfortable and well-fitted to my truck?
As he used to say while explaining centrifugal force - "Imagine you're on a date, in your car with a bench seat. If you really like your date, you make lots of right turns. If you don't like your date, you make lots of left turns. And if you really don't like her, you make sure her door is unlocked first."
MIKES 68 F100
19
01-05-2015 06:01 AM
