1998 f150 4.2 loud engine tapping
hello guys , i dont own an f-150 but i own two fords , a 01 crown vic and a 93 thunderbird sc. im posting this for my father in law.
he has a 1998 f150 with the 4.2 engine in it. it has 100,000 miles . today when he started it there was a loud tapping noise from the engine , it runs great , doesnt shake and the noise goes faster when you accelerate the car.
a mechanic came today and ran codes , i wasnt there so i didnt see the codes , i know they were p03 something which tells me a missfire and then he said they said p1 or p2 after the code. he told my father in law the engine was no good. i doubt it.
sounds like a rocker arm loose.. you could really hear it in the front part of the engine . what could it be ???
thanks.. sry for the long post
umm i don't wanna say something stupid but you sure its not an exhaust leak? i have a 98 f-150 with a 4.2 it currently has 150000 on it. at about 120000 a pipe coming off the passenger side mannifold rotted out and caused an exhaust leak, it sounded like a horrendous knock. but i inspected it and new it was an exhaust leak, the truck ran fine. so i fixed it, at 135000 the driver side manifold cracked and made the same noise and i replaced that and it took care of it. you could very well have a serious motor problem but this is just some things that have happened to my 4.2. also at 85000 my number six spark plug rotted in half and caused the truck to run like **** till i changed the plugs. he may have a rotted out plug. i hope this helps you, other than that the running condition of my 4.2 has been flawless for 10 years.
I have a 98 4.2l manual and it has 286,000 miles on it. It has started to knock right behind the driver side tire, but once I shift into 3rd gear going down the road it leaves. Some days it starts without the noise. It drinks radiator fluid like sponge, and I just did a oil change and it was dark black. I have read where these engines have been plagued with the timing gasket leaking fluid into the oil and tearing **** up! I have a 04 engine off a wacked truck ready to replace the 98 but before I jump into changing engines, can anybody tell me this is something else? I don't have a lot of $ to do a lot.
