thermostat
Old 03-24-2008, 08:22 PM
reifwj's Avatar
reifwj
reifwj is offline
thermostat
From what I know about thermostats, the correct thermostat depends on the altitude, winter temps, summer temps, and most important, truck usage. When i was removing the heads to get the sheered exhaust bolts, i noticed the truck did not have a thermostat. I guess that explains the lack of heat this winter. What temp thermostat do you recommend? I'm running a stock 360, my elevation is 3000 ft, winter temps are around 20s, and the summer is up to 115. This truck will be used pretty much as sunday driver.
Old 03-24-2008, 09:06 PM
whitetrash's Avatar
whitetrash
whitetrash is offline
I had a 360 in a 73 that I ran a 160 in when I was in Utah. That’s just what it had in it when I replaced it, I don’t know how to determine what best temp is. There are a lot of smart folks here that will give you all the info you will need. Where in Idaho does it get to 115?
Old 03-24-2008, 09:16 PM
reifwj's Avatar
reifwj
reifwj is offline
Boise. We had two weeks of temps over 110 in 2006. only a couple days last year.
Old 03-24-2008, 10:59 PM
seafire's Avatar
seafire
seafire is offline
Here Idaho I run 160 temp. I have one in my 70 F100 "302" and 67 mustang "289" and they both work good for me. I also had the same in a 351M
Old 03-25-2008, 04:55 AM
jowilker's Avatar
jowilker
jowilker is offline
A 180º or 195º would be proper, along with a 50/50 mix of coolant and water. I believe 180º is what came from the factory. Bill will know for sure.
John
Old 03-25-2008, 08:52 AM
whitetrash's Avatar
whitetrash
John are you saying a 160 and a12 pack beer carton in front of the radiator was not standard equipment
Old 03-25-2008, 12:10 PM
bertha66's Avatar
bertha66
bertha66 is offline
I run a 180 here in Central Oregon, I'm at 3000 feet also and it has worked good.
Old 03-25-2008, 12:25 PM
jowilker's Avatar
jowilker
jowilker is offline
Chad, That is not my recollection, from when they were new.
John
Old 03-25-2008, 06:14 PM
DarkWolf40's Avatar
DarkWolf40
DarkWolf40 is offline
Napa told me 195 was stock, thats what I'm running and it seems to run better than when I had a 160 in there
Old 03-25-2008, 11:06 PM
Danger_Dave's Avatar
Danger_Dave
Danger_Dave is offline
i run a 205 in the winter which really bakes your butt! and a 175 in the summertime. i have a little assortment of thermostats. at 180 degrees the motor seems to perform the best. and yes i think that is what comes in them stock.
Old 03-26-2008, 11:11 AM
qman's Avatar
qman
qman is offline
I do not believe altitude and temps have anything to do with it. The tstat controls the temp that your engine runs at and I think 192 is stock. When you get a replacement you get a 195. The 360 in my truck had a 160 in it when I bought it and it didn't run real well. I put in a 195 and it runs great now once it's warmed up.
Old 03-26-2008, 07:42 PM
Bookman's Avatar
Bookman
Bookman is offline
I also had a 180 in it and just replaced with a 195 from NAPA which is what is called for. I noticed an improvement with the general run of the motor. My understanding is that Fords like to run a little warmer to get the most out of them. I can tell you it runs better after warm up.
fordtruck88
01-30-2005 07:49 AM
morrigj83
03-20-2004 08:41 AM
RabidJade
11-08-2003 10:24 PM
ford429cu
12-30-2002 10:57 AM
brents
12-01-2001 11:51 AM
Quick Reply: thermostat
