Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
  #1 (permalink)
Old 03-24-2008, 08:16 PM
puddlejumper puddlejumper is offline
Garage is empty, add now
puddlejumper is starting off with a positive reputation.
f-150 lightning help please.
i am selling one of my 69 camaro,s and looking to buy a 2000 or newer ford f 150 lightning . i need to know is there a year i dont want and what things should i look for or ask about concerning the lightning trucks. i have noticed most people seem to sell them after 37,000 up to 97,000 is there a reason for this.
in simple terms educate me on purchasing a lightning please so i can assure i get a good deal. i have never been one to run vehicles i have to have smogged but lately im wanting a newer performance vehicle and i like the lightning . so if you guys could please educate me on the lightning. thanks.
  #2 (permalink)
Old 03-24-2008, 10:32 PM
surely some of you must have some info or advice for me ???
  #3 (permalink)
Old 03-24-2008, 11:21 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
1994 Ford Lightning
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
The 99-02 had issues with the spark plugs coming loose; just check them every now and then and you should be ok. I think there may be more, and one of the GEN 2 owners will chime in.
Otherwise, take it for a test spin and don't be afraid to get happy with the GO pedal. The GEN 2's are solid trucks and can tow/haul the same as any other F-150.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, 62lb injectors, 2800 stall converter, Eaton Locker, Pickrel Headers and Exhaust, FMS Mass Air using SCT tuning software. Road trip and dragstrip ready!
  #4 (permalink)
Old 03-29-2008, 02:01 AM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
1999 Ford F-250
My Garage
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
Originally Posted by puddlejumper
...looking to buy a 2000 or newer ford f 150 lightning . i need to know is there a year i dont want and what things should i look for or ask about concerning the lightning trucks.
I've answered this question on this forum over the years, and have compiled my responses to make it easier to answer whenever the question invariably arises. So listed below, is the info you seek.
'99-'02 model year had the heads with 4 threads per spark plug holes. This causes a situation where the spark plugs are easily launched from the heads.
This problem is not limited to the Lightnings, as all the modular engines Ford made have this problem.
Starting with the '03 model year, Ford started using heads with more threads in the spark plug holes.
Don't let the plug launching scare you tho. All you need to do is make sure your plugs are torqued to the proper value (12 - 13 ft lbs) and check them every 6 months or so and you'll be fine.
There were intercooler issues on the '99/'00 models. Ford offered a replacement under warrantee though, so most would have been replaced because they leaked like a sieve.
The '99 and '00 model year L's produced 360hp and 440 ft. lbs of torque and had 3.55 gears in the diff.
Starting in '01, due to slight changes by Ford (80mm MAF to a 90mm MAF and some other tweaking), the L's produced 380hp and 450 ft. lbs of torque and were now sporting 3.73 gears in the diff.
Ford also stopped using the 3.5" steel driveshaft and started putting a 4.5" aluminum driveshaft in the L's in '01.
All of the Gen 2 L's have the 4R100 tranny. A very stout unit used by Ford for the 7.3L PSD's.
That's all I can think of off the top of my head.
As for determining if it's been beat on, look for obvious stuff. Has it been modified and how extensively? If it has been modified, were there any custom tunes put on the truck? If so, how? Chip or flash and who wrote the tune? Someone reputable?
I'd also check how many owners the L has had. Are you buying from a younger adult or an older adult?
One thing I do is look at the engine bay. You can USUALLY ascertain if the present owner has kept the bay clean, or if its just been recently cleaned because it's for sale.
I look for this because, even though its very subjective, usually if the owner is meticulous enough to keep the engine bay clean all the time, then he has an eye for detail and will usually treat/work on/modify and generally take better care of the truck than someone who doesn't clean the engine bay.
Again, that's not a hard and fast rule, but I've found it to be true more times than not.
Get an Oasis report and a Carfax. You can never have too much info.
If you start comparing mileage on different trucks, remember it's all relative. You can have one truck with less than 30K miles on it, has been modified with a chip, pulley, CAI, custom tune, etc and it's been beat to heck, ran hard, and raced at the track every weekend. Compare that to another truck that has 100K miles on it, but has very few mods, and has never been raced.
It's all subjective. It's something only you can decide, because lets face it, the youngest Gen 2 L is four years old, and the oldest Gen 2 L is 9 years old.
Stewart
__________________
The Brotherhood of FTE <-click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff
2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes
Never Fry Bacon NAKED!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
