anyone got pic of there ECU?
on
I can't see the pics due to the filter on this computer but here is a pic of the PCM location
To install a chip though you have to remove the driverside kick panel and remove the three nuts that hold the parking brake in place. its pretty tricky to clean the PCM contacts in the truck though. it can be done but take your time.
on
To install a chip you don't need to unplug the PCM. The underdash end is where the Chip goes. Just make sure the keys aren't in the ignition. It is easier to clean the chip contacts with the PCM out of the truck so if you want to go that route you can. If its anything like my truck was it won't be fun to remove the PCM.
When a picture doesn't show up like expected:
Right-click on the red X, select properties, highlight and copy the URL, paste it into the address bar at the top of your screen, and press enter to view the picture.
Use your "Back" button to return. Sometimes, but not always, doing this will also allow the picture to display normally.
on
