2008 aftermarket Subs
you want some more bass huh?!?!?!?! and do you want to do it with not going with too much power? ok here is your cure!!!
www.proboxrocks.com
don't get fooled by a single 10 inch woofer! it will rock your truck, i've heard this set up and it unbelievable! i had 2 8 inch woofers and its rocks *** and i listen to hip hop music.
www.proboxrocks.com
Also, check out http://www.tech12volts.com/. He does a lot of custom boxes, and is supposed to be a great guy to work with.
Originally Posted by XolieX
after checking out the boxworx, he sounds like he knows whats goin on!
Originally Posted by bgalaxy67
That guys got all sorts of crazy installs! 20 12's in a civic CRAZY, liked the "custom" bed he did, pretty sweet!
Originally Posted by paperhanger
Hey X, you seem to have some good advise. I just bought a Shaker 500 out of a 2006 mustang to install in my 2005 f150 xlt with single cd. I want the factory look so aftermarket was not an option. I have already installed new door speakers front and rear and am looking for a factory sub. Any thing that I can do to make it a killer system. Also looking for the sub plugs, any suggestions?
Did any of the 150's come with a factory sub option?
http://www.spl2k.com/boxworx.html
kinda exactly what this guy is selling.
Stealth boxes, and an amp that are hidden would look factory. Unless you showed them to someone. The amp can be wired to work off fo your stock unit. There would be a loss in sound quality, i belive, but not a huge one.
Just switched the single cd head unit for the Shaker 500. Big sound difference even without the sub, now I HAVE to get a sub. The light dimming problems some people have is non existent, it works fine. I now need to get the wiring and plugs for the sub. There was no connectors in the dash that I could find, oh, the truck is a 2005 f150 xlt, single cd was the stock radio. What type of wiring should I be looking for and any good sub suggestions. I am looking into the thunderform.
As hop will have to tie into one of the speakers for signal and then you will have to run seperate power for an amp to power the sub.
A small amp and sub installed shold be an easy cheap one from any car audio shop. It's a simple add so if a shop says they can't do it or shouldn't then your at the wrong shop.
Just don't let a salesman sell ya on a whole new system. If your overall happy with the way it sounds now then add what you want, not what someone makes commission on.
