2008 aftermarket Subs
Old 03-02-2008, 03:50 PM
Hollywood2005's Avatar
Hollywood2005
Hollywood2005 is offline
I have a 08 with the audiofile stereo system and need more bass and am having problems finding any custom fit boxes... does anyone know of any?
thanks
Old 03-08-2008, 09:35 AM
XolieX's Avatar
XolieX
XolieX is offline
you want some more bass huh?!?!?!?! and do you want to do it with not going with too much power? ok here is your cure!!!
www.proboxrocks.com
don't get fooled by a single 10 inch woofer! it will rock your truck, i've heard this set up and it unbelievable! i had 2 8 inch woofers and its rocks *** and i listen to hip hop music.
Old 03-08-2008, 10:21 AM
rex4570's Avatar
rex4570
rex4570 is offline
Also, check out http://www.tech12volts.com/. He does a lot of custom boxes, and is supposed to be a great guy to work with.
Old 03-08-2008, 04:08 PM
bgalaxy67's Avatar
bgalaxy67
bgalaxy67 is offline
Try this guy. http://www.spl2k.com/boxworx.html
He knows a thing or 2 about sub boxes.
Old 03-12-2008, 07:52 PM
XolieX's Avatar
XolieX
XolieX is offline
after checking out the boxworx, he sounds like he knows whats goin on!
Old 03-13-2008, 09:47 AM
Hollywood2005
thanks for your help guys!!
Old 03-13-2008, 01:11 PM
beefeater's Avatar
beefeater
beefeater is offline
JL audio is offering a very interesting looking custom sub enclosure that is made to fit within the center console of the 08 SD.
Not sure how much of the center console it would use up though. Check it out at Crutchfield or JL Audio websites.
Beef- Its what's for dinner.
Old 03-15-2008, 06:39 AM
paperhanger's Avatar
paperhanger
paperhanger is offline
Hey X, you seem to have some good advise. I just bought a Shaker 500 out of a 2006 mustang to install in my 2005 f150 xlt with single cd. I want the factory look so aftermarket was not an option. I have already installed new door speakers front and rear and am looking for a factory sub. Any thing that I can do to make it a killer system. Also looking for the sub plugs, any suggestions?
Old 03-15-2008, 07:07 AM
Truckin4life's Avatar
Truckin4life
Truckin4life is offline
Street Queen to the extr3m3
nah that guy dont know JACK!!!! ha ha ha ( note saracasm )
That guys got all sorts of crazy installs! 20 12's in a civic CRAZY, liked the "custom" bed he did, pretty sweet!
Old 03-15-2008, 11:41 AM
bgalaxy67's Avatar
bgalaxy67
Good question.
Did any of the 150's come with a factory sub option?
Old 03-15-2008, 12:40 PM
Truckin4life
None i can think of off top of my head, could go the loc route with aftermarket amp and stealth box.
Just an idea.
Old 03-15-2008, 01:51 PM
bgalaxy67's Avatar
bgalaxy67
I think you could find something aftermarket that looks factory.
You can still tap into the factory system and add some nice low end.
Old 03-15-2008, 07:28 PM
Truckin4life
kinda exactly what this guy is selling.
Stealth boxes, and an amp that are hidden would look factory. Unless you showed them to someone. The amp can be wired to work off fo your stock unit. There would be a loss in sound quality, i belive, but not a huge one.
Old 03-16-2008, 09:03 AM
paperhanger
Just switched the single cd head unit for the Shaker 500. Big sound difference even without the sub, now I HAVE to get a sub. The light dimming problems some people have is non existent, it works fine. I now need to get the wiring and plugs for the sub. There was no connectors in the dash that I could find, oh, the truck is a 2005 f150 xlt, single cd was the stock radio. What type of wiring should I be looking for and any good sub suggestions. I am looking into the thunderform.
Old 03-16-2008, 03:14 PM
bgalaxy67's Avatar
bgalaxy67
You won't be able to just plug in a sub into the deck.
As hop will have to tie into one of the speakers for signal and then you will have to run seperate power for an amp to power the sub.
A small amp and sub installed shold be an easy cheap one from any car audio shop. It's a simple add so if a shop says they can't do it or shouldn't then your at the wrong shop.
Just don't let a salesman sell ya on a whole new system. If your overall happy with the way it sounds now then add what you want, not what someone makes commission on.
Quick Reply: 2008 aftermarket Subs
