Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-20-2008, 10:54 PM
blue beast's Avatar
blue beast blue beast is offline
Garage is empty, add now
blue beast is gaining momentum as a positive member of FTE.blue beast is gaining momentum as a positive member of FTE.
Exclamation Bio mass GASIFICATION wood gas!!!!
I am getting the supplies needed and I am going to start building my wood gas
generator and I already have a few ideas to try and make it more effecient!!
I am ging to start on a small scale just for my generator and work out the
kinks and then try to up size it and maybe just use the wood gas to supplement my regular gasoline that way I can run on either.
If you search around the internet and use that babelfish translator there are
a bunch of guys in europe that are using these on their cars. Some are putting the unit on a trailer and towing it around, I don't like that idea!! This is really old technology and we here just never got around to messing with it since fuel has been pretty cheap and it seems like a lot of work, since you have togo out and "Fire up" your car way before you plan on leaving. But fuel is going up and up and it is looking attractive to a lot more people. Everyone I tell about it wants one right now!! I think of all the trees that were removed and burnt or buried for all the houses that were built in the boom and think man all that fuel that was wasted!! Many different items
can be used for fuel and scrap wood from construction, all that crappy
particle board furniture that is always at the curb, charcoal, that wood
pellet fuel, coal, lignite, cow manure just about anything that has any chance
of catching fire can be used for fuel. The process isn't burning the fuel with
a fire it basiclly just heats the constituents out of the fuel and you burn the
gas(kind of like propane more than gasoline)
http://www.gengas.nu/byggbes/index.shtml
__________________
86 fs bronco 302 auto 33x12.50 at rusty but trusty!
91 ford probe lx mtx The mighty vulcan 3.0
Before posting fuel related problems Run a couple of bottles of dedicated gas line dryer through IT!!
  #2 (permalink)
Old 04-02-2008, 11:05 PM
Marianna2003 Marianna2003 is offline
1992 Ford F-350
My Garage
Marianna2003 is gaining momentum as a positive member of FTE.
I considered building a gasifier. Sweden has done a lot of work on them. They import all of their fuel. You pointed out the biggest drawback to gasification. The time required to fire up and go. In searching around the Internet I came across a website about a guy that ran hydroplane boats on 100% Brown's Gas (a mixture of Hydrogen and Oxygen created by the electrolsis of water) or HHO. He has free plans to build a system that uses an 800 watt inverter coupled to a couple of circuits he gives on the site. There are demos on Youtube if you're curious. http--pesn.com-2007-09-29-9500450_BobBoyce_Electrolizer_Plans-d9.pdf is the website.
The HHO system is almost instantaneuos. You can use a small version to increase the efficiency of the existing fuel for a lot less investment. The best thing I can say is read the article at the website, it's very informative.
  #3 (permalink)
Old 04-02-2008, 11:07 PM
1992 Ford F-350
My Garage
http://pesn.com/2007/09/29/9500450_B...r_Plans/d9.pdf is the correct address.
  #4 (permalink)
Old 04-03-2008, 01:23 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
The title "Practical Guide to 'Free Energy' Devices" should be a big clue that by and large, it's BS and/or scam, even if the particulars may be correct in many cases.
The only 'Free Energy' comes from the Sun (or to a much lesser extent, the internal heat of the Earth and radioactive decay) and not from mucking around with a non-existent "hydroxi gas" or "HHO".
  #5 (permalink)
Old 04-03-2008, 05:36 PM
LastSplash LastSplash is offline
LastSplash is starting off with a positive reputation.
There is no such thing as "free" energy, according to the 1st law of thermodynamics.
__________________
'97 F-150 XLT S/C 8' bed Leer fiberglass shell
  #6 (permalink)
Old 04-04-2008, 03:55 PM
jimandmandy jimandmandy is offline
jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.jimandmandy has a great reputation on FTE.
Here are the basic equations, where CH represents a generic hydrocarbon fuel, such as coal or wood. There are other constituents, such as nitrogen and sulfur, but they are not part of the reaction.
CH + 5/4 O2 --> CO2 + 1/2 H2O normal combustion, exothermic (produces heat)
CH + H2O --> CO + 3/2 H2 endothermic reaction (requires heat)
CH + 1/2 O2 --> CO + 1/2 H2O incomplete combustion, slightly exothermic
The resulting gas mixture of CO, H2, and N2 (inert) is very low in energy content, about 200btu/cuft compared to natural gas CH4 at 1000btu/cuft. My question is; how do you burn this gas in a spark iginiton internal combustion engine that requires a near perfect air/fuel ratio? Do they run it in diesels? If so, how does the fuel injection system work?
Jim
  #7 (permalink)
Old 04-05-2008, 08:06 PM
1992 Ford F-350
My Garage
You could fumigate your diesel with The gases from a gasifier. It would simply supplement the fuel your IP puts out. The gases will not self ignite and therefore they wait for fuel to light them off. You may get a catalytic effect in that the gaseous products will cause the diesel fuel to burn more completely. All of this to say that you will get better fuel economy as long as you don't go overboard with the producers' gas.
  #8 (permalink)
Old 04-05-2008, 09:17 PM
monckywrench monckywrench is offline
monckywrench is a name known to allmonckywrench is a name known to allmonckywrench is a name known to allmonckywrench is a name known to allmonckywrench is a name known to allmonckywrench is a name known to all
Wood gas generators go back many years, and some US farmers and other folks with access to wood waste use them. Farm Show magazine had a recent article on a fellow who used his tubular pickup bed rack to cool the gas prior to burning. it works in spark ignition engines, but is really only useful for folks with great fab skills and lots of free wood.
Cool pic of an old tractor conversion:
Image:Wood gasifier on epa tractor.jpg - Wikipedia, the free encyclopedia
The Browns gas scam is famous, but do spend your money on a system and then hook up to an independent third party dyno under repeatable lab conditions and prove the naysayers wrong. I've decided to encourage everyone who believes in this stuff to put their money into it for the entertainment of the rest of us.
  #9 (permalink)
Old 04-05-2008, 09:26 PM
66slick's Avatar
66slick 66slick is offline
66slick is starting off with a positive reputation.
Just put a steam engine in box LOL. Actually they used to build steam powered cars back in the day. Apparently they had a lot of power.
__________________
"I think I'll get in my truck, drive to the fridge and get myself a beer"
  #10 (permalink)
Old 04-05-2008, 09:29 PM
"Actually they used to build steam powered cars back in the day. Apparently they had a lot of power."
Full torque at zero rpm, according to the old Stanley enthusiast I knew in my youth.
  #11 (permalink)
Old 04-07-2008, 09:46 AM
It takes too long to "start" a steam powered car. The time necessary to boil the water was excessive, especially compared to a spark-ignition ICE. There was also danger of explosion.
That link to a picture doesnt even show it moving. Again, how is wood gas actually inducted and burned in an engine?
Jim
  #12 (permalink)
Old 04-07-2008, 11:51 AM
magusjinx's Avatar
magusjinx magusjinx is offline
magusjinx is starting off with a positive reputation.
I like the "free" HHO systems ... They usually forget to tell you where to get the initial electricity to split the water molecules ... Now if you used solar to do the splitting at home and had your own storage tanks then it would be "less expensive" ... But can ya pull a loaded 40 foot 5th uphill at even 35 mph?
__________________
USMC '74-'78
1986 Ford F250 Explorer XL--4x4, 6.9 NA IDI, C6
1986 Jeep Cherokee Pioneer Limited --2.8L V6, Automatic
  #13 (permalink)
Old 04-07-2008, 05:02 PM
"There was also danger of explosion."
That's easy to avert with modern materials, and water-tube boilers.
"That link to a picture doesnt even show it moving. Again, how is wood gas actually inducted and burned in an engine?"
The pic wasn't intended as a construction tutorial. Expect to spend many hours of internet searching to learn about systems, including finding appropriate newsgroups if they exist for your specific interest. It will be a massive amount of study and effort, and involve money, fabrication, and trial-and-error. There are plenty of good reasons that alt energy is a niche hobby.
I got the link below from Google Image Searching (a good trick to sort useful links) "wood gas Imbert system".
3.1 Overview of development work and testing carried out at the national machinery testing institute
  #14 (permalink)
Old 07-08-2008, 04:11 PM
fud24682000 fud24682000 is offline
fud24682000 is starting off with a positive reputation.
Can woodgas be compressed and stored?
If it could be compressed into a tank as is done with propane and CNG, it seems to me it would make sense to have a stationary woodgas generator to fire up from time to time and store the gas in cylinders. The time needed to fire up for each trip and then hauling around bulky generating equipment, filters, etc. is a drag. Besides, the woodgas generator is always making either too much or too little gas unless you drive at a steady speed and can control the amount of gas generated.
Granted, the energy content of woodgas is low, but it might simplify things if it could be stored and used as needed.
Ray Mac
  #15 (permalink)
Old 07-09-2008, 01:07 AM
If you want to go the extra mile about compressing and all that, you'd probably be better off with either CNG or H2. Wood gas is simply not practical in most cases. The only situation I could think of if a vehicle is used in a place where there's no gasoline, but there are wood, like remote places in Siberia or Alaska. But then wouldn't be many roads there either.
Tags
colorado, content, energy, ford, fumigation, gas, gasification, gasifier, generator, ice, pdf, pickup, plans, truck, wood, woodgas, youtube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
