400m horsepower
Old 07-27-2000, 09:23 PM
chevykiller's Avatar
chevykiller
chevykiller is offline
400m horsepower
how much horsepower does a stock 400m have.and how much might you gain adding a edlebrock intake and a 4 barrel carb.
Old 07-28-2000, 05:29 AM
Bob_VT's Avatar
Bob_VT
Bob_VT is offline
400m horsepower
Depending on the year the 400M ranged from 180 hp way back in 1976 to around 166 hp in 1978. The tourque was around 319-336 ft lbs.
Let me see if I remember that rule of thumb formula..... Oh yea.
HORSEPOWER = MONEY (which few of us have) SO HOW FAST YOU WANT TO GO!!
Adding a 4bbl with new mainfold is a good start however, changing the cam along with the exhaust will help. There is a 400 hp formula for the 400M engine out there. Remember what the purpose of the power is. If you want pulling power tourque is the answer. If you want pure redline high horsepower the tourque end will suffer and your truck will not pull the low end side as well as a stock engine.
Make your choice carefully (at the national average of $1.67/gal for gas). 400M's were never respected for gas mileage.
Old 09-09-2000, 02:11 PM
Bill_Beyer's Avatar
Bill_Beyer
Bill_Beyer is offline
400m horsepower
>carb.
First off it's a 400 not a 400M. Second you need to bump the C.R. and put a decent cam in to make any serious horsepower. The engine doesn't breathe well with the cam it's got despite the excellent heads. Frankly you won't be gaining much at all on the bottom end, maybe a little extended RPM range...
Old 01-14-2003, 07:41 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
400m horsepower
djmichael24951
08-17-2013 03:39 PM
78fordbeast
01-26-2013 05:16 PM
1big79
12-27-2005 02:49 PM
1big79
11-07-2003 06:08 PM
78orangeford
43
09-16-2001 07:08 AM
Quick Reply: 400m horsepower
