Radiator Question,
I installed an aluminum 2-row (1" tubes), stainless flex hoses, hav'nt fashioned a shroud yet...was gonna look at the universal stainless ones like Summit sells.
I think I have an air pocket in the system that I need to bleed out-temp guage and sender are new but seem to read a little high...I think its because of an air pocket.
If budget had been bigger I think I would have gone for a custom built copy of the original (all polished up)!
Ed
Ed
Go to the US Radiator and the RadiatorBarn websites, both places have great online catalogs that will give you all the dimensions on radiators from different makes and models. You can also get all the dimensions, including inlet/outlet size and locations as well as mounting bracket info.
After you have narrowed your search down you can order the radiator online or sometimes you can get lucky and pick one up from your local auto parts store.
If the inlet/outlet size doesn't match your engines inlet/outlet you can get step up/step down radiator hose bushings from NAPA Auto in 1/4" increments from 1 1/2" up to 3"
In my case I'm using a mid 70's Dodge truck radiator in my 49 F1 with a 500ci Caddy
I have heard that mid 70's Ford truck radiators are almost a direct bolt in for the 53-56 trucks
Happy hunting
Bobby
Happy hunting
Bobby
Ed
Ed
Griffin 2 row radiator. 1 1/4" tubes. Core thinkness 2 3/4". Tank width 3". Special order with mounting bracket attached flush with the engine side of the radiator instead of the center of the radiator (this created more room for the fan - radiator sits closer to the front of the pickup). Modified the radiator support so the radiator sits lower - top of the radiator tank almost even with the top of the radiator valance, I also added two mounting brackets to the radiator support for the overflow tank. Custom fan shroud with electric puller fan. Used ford shock absorber bushings between the radiator support and the mounting brackets to isolate the radiator from vibration. Looks great and performs well.
Shane
1956 F100
Happy hunting
Bobby
Happy hunting
Bobby
twofifty
06-20-2016 06:07 PM
Oldcrowbarber
26
05-20-2016 04:20 PM
mcne
09-22-2005 07:40 AM
