300cid to 460 engine swap in my 1986 F150
Old 03-12-2008, 03:10 PM
Ladman's Avatar
Ladman
Ladman is offline
im going to be doing an engine swap in my 1986 ford F150 2wd from the inline 300 to a 460. i have heard alot of things and wanted to get a few cleared up.
one, i heard that i can use my existing T19 but get a different bellhouseing. is this ture?
Two, i also heard that i might need a bigger clutch?
so if some one could just clear up a few things for me it would be much apprichiated
Old 03-12-2008, 05:52 PM
uncle.stosh's Avatar
uncle.stosh
uncle.stosh is offline
460 bell housing is definately different (good luck finding one), and yes you'll need a bigger clutch.
With gas prices approaching $4.00 a gallon, why would you want to do this swap if you don't mind me asking, and what are you going to do with the 300?
Old 03-12-2008, 06:01 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,680 Likes on 1,357 Posts
A 351m/400 bellhousing might fit too. You can go to www.partsamerica.com like did, and look up a 86 f250 with a L6, and then a 86 f250 with a 460. You have to look up a f250, since the f150 never had a 460. The 86 L6 was offered with a 10" and a 11" 10 spline clutch set. The 460 was offered with 11" and a 12" 10 spline clutch.
Old 03-12-2008, 06:03 PM
Ladman's Avatar
Ladman
Ladman is offline
sweet deal thanks guys, to answer the question what im going to do with the 300, one of two, give it to my dad to put in his 78 ford f150 or sell it
Old 03-12-2008, 06:14 PM
andym's Avatar
andym
andym is offline
A 351m/400 bell won't work unless you also convert back to a mechanical clutch, which I don't recommend you do.
Old 03-12-2008, 06:17 PM
Franklin2's Avatar
Franklin2
And I forgot to add, even though both came with a 11" clutch option, they have different part numbers, so something is different about them somewhere.
Old 03-13-2008, 10:42 PM
bobzdar's Avatar
bobzdar
bobzdar is offline
Doesn't seem like a very good swap...If you want to tow/haul stuff you'd want an f250 or f350, so why the 460? If you want to go fast, get something that weighs a little less than a pickup and put the 460 in that.
My 460 powered ford is by far the worst vehicle I own for fuel economy. Even my '67 grand prix with 428HO and tripower gets 12-13mpg...and it's almost as big. Good luck with the swap.
ghostshark
WTB - Parts & other
02-21-2016 02:26 PM
HarleyLover
01-03-2016 03:47 PM
Cowsavy
New Member Introductions
01-04-2015 01:09 AM
Bullride_101
02-02-2009 09:49 AM
1986f150
04-23-2002 01:23 AM
Quick Reply: 300cid to 460 engine swap in my 1986 F150
