Severe Engine sludge, What causes it.
I broke my old engine down yesterday and found it had sludge in the oil pan and under the valve covers, so thick it had the oil pump pick-up screen stopped up. What causes this? Remember all I bought the truck used and in the shape it is in, got a good deal on it only $600.00 for the truck. I WILL run Mobile 1 oil in the new Engine.
Originally Posted by EPNCSU2006
Not using castrol motor oil will cause sludge buildup, according to their commercials
Sludge buildup is either a crappy oil, or never changing it.
The oil itself might contain paraffin and other waxes, and if it isn't changed often enough, that stuff will buildup over time. And if the oil has enough of that stuff in it in the first place, changing it often won't help.
Use a good quality oil, and you won't have a problem.
Originally Posted by Mike G
Lack of oil changes, extended periods of sitting exposed to the elements, lack of long-run trips, exposure to extreme conditions (dusty/dirty) and lastly, incorrect weight or bad oil brand choices.
Just my few thoughts, --Mike
Originally Posted by jimdandy
Plus 1. Mainly moisture build up. Also, there is nothing wrong with Pennzoil. Old wives tale. jd
I've been running pennzoil for every car I've owned. My dad and grandfather have both ran it with none of this "build up" stuff everyones talking about.
When I opened up the 351 in my bronco there was NO sludge. This is with 158K miles. My dad's truck was opened up at 160K miles and it looked so clean you could eat off of it. He bought the truck new and put ever mile on it with pennzoil. This is just silly.
Matt
Originally Posted by 85e150six4mtod
Non-op PCV will help build it up, but this sounds like a combo of things..
If the engine has an aftermarket type air filter, check to see what was done with the PCV hose.
korze
03-12-2016 02:33 PM
Cruiseomatic
General Automotive Discussion
10-31-2012 02:29 PM
