Setting inital timing with incorrect timing marks and recommened timing settings.
Old 10-01-2001, 04:08 AM
Bull's Avatar
Bull
Bull is offline
I installed MSD Billet Distributor a couple of days ago in my 78 F250 with 400 engine and found out that my timing marks are way off so I just set the timing for max rpm at idle for now. Would that be a good inital timing setting to run until I can get the timing marks lined up right? Also, what's the recommened max ignition timing and at what RPM for stock compression engine with MSD 6 box, Blaster 2F coil, headers, and dual 3" exhaust?
Old 10-01-2001, 09:55 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
Run up a hill in high gear and see if it pings. If it does, set the timing back till it goes away. If the starter spins the engine ok when it's warm, this will probably be a good setting for max power.
Old 10-03-2001, 07:09 PM
Bull's Avatar
Bull
Bull is offline
Thanks for the reply, I don't hear any pining at WOT going up the hill... I just hope that my exhaust isn't masking any pinging that may be present.
Old 10-03-2001, 08:52 PM
thelonerangerxlt's Avatar
thelonerangerxlt
thelonerangerxlt is offline
william16339
10-24-2016 02:37 PM
travisb6989
General Diesel Discussion
25
03-14-2011 08:06 PM
yeahbuddy24
12-18-2009 03:21 PM
61F750
02-18-2006 12:16 PM
fordeverpower
04-03-2005 08:06 PM
Quick Reply: Setting inital timing with incorrect timing marks and recommened timing settings.
