door hinge question
door hinge question
Guys, my front drivers door is rubbing against my front panel at the bottom. I checked the pin and it does seem to have a little play in it (but really not much)...even when I lift the door, it still rubs. I see that the hinge is fixed to the truck with 3 bolts per hinge. My question is, can I remove the door from the hinge to gain access to the bolts that hold the hinge to the truck, loosen the bottom hinge bolts and set it to the rear slightly? In other words, is there some allotted play in the hinge mounting bracket?
Thanks
Itch
Thanks
Itch
Yes u can I hang door from garage door track with a strap. The when you unbolt door it will be supported (way easier than putting something under it to hold.) You then can access the hinges. You can do pins/bushings in truck but . If door has that much sag I bet the upper or botom is worn to much for fix to last . (just look once pin is out if the bushing is worn so much that its wearing hinge its self replace it.
Itch
wavetrain75
01-09-2013 09:23 PM
Roamer
05-08-2009 07:46 PM
Roamer
'80-'86 FAQs (Frequently Asked Questions)
05-08-2009 07:46 PM
