Fabtech 2wd front lift I'beams & cont arm F/S
Not sure if this is the correct place to post this...
I came across a Fabtech front suspension, includes the spindles, rotors & calipers... I picked it up cheap, it was pulled off a 80's something 2wd... the guy I got it from said the owner converted it to 4x4... Anyway, I got it thinking I would modify it to make drob beams for my 66 and use the newer ball joint spindles and disc brakes... but then I picked up a 79 donor that makes it easier to convert to P/S & disc brakes...
So I have this suspension if someone want to lift a 2wd and make a Prerunner truck...
I'll pass on the great deal I got for the stuff... $200 for all
scskysc
06-13-2015 02:48 PM
