dana 44 5 to 8 lug swap
Received 3,122 Likes
on
on
yup, D50 TTB.
i doubt very much it was a D44 TTB, cause it came out of a 87 F250 diesel 4X4 that we swapped a D60 into, and tossed the TTB setup after stripping it.
we may have used the hubs and spindles. i can't remember though.
what i do remember of it was the 76 F150 sitting there with siezed calipers and wasted rotors, and i said lets see if the TTB stuff will fit. and then stuffing an 8 lug D60 into the rear end a few weeks later so it was full 8 lug.
Yes- And it has to be a D44HD TTB if you have to swap the spindles as well. The D50 TTB has more bolts holding it on.
D44HD straightaxle on right, TTB on left:
My 84 F250 4x4 TTB had the same spindles as the D44HD I replaced it with.
FWIW, this will gain you no strength at all, the weakness is the axle tubes and universal joints. The D44HD has about a 3/4" larger diameter tube, with almost all of that being in wall thickness, but about the only thing you can do about the universals is get an upgraded set and axles.
i am hoping to not have to change the spindles. i am rebuilding a 77 hp d44, and i have access to a free 85 f250(whole truck) so i was going to take the d60 rear and use the ttb front to convert my d44 to 8 lug. hopefully this will work like you said, and be the cheapest 8lug sas ever.
as far as strength goes, i believe these axles under a 2 door explorer will be more than adequate.
i have also read about upgrading the master cylinder to compensate for the larger brakes, would this be needed in my application?
i would appreciate any and all tips on the conversion, hell even the sas!
thanks ford_six
Caveman2851
05-11-2015 06:13 AM
