HPOP Lines
HPOP Lines
Hey Everyone
This is my first post and I just wanted to say hello. Today, I had an oil line that blew -the one that comes from the HPOP to the cylinder head. I tried to call NAPA and they said it was a dealer only item. Just wanted to know if anyone had any part numbers for International or anyone else. I want to replace both lines, (passenger side and drivers side). Any help would be greatly appricated.
Thanks!
Mike
Thanks!
Mike
did the line fail or was it the seals?
I had the seals go in mine and before I found this forum I had a "Stealer" I mean dealer replace them. I am sure some one here can tell you where and what to get. The next question is do you have the time and tools to replace them?
I was on my way back from B.C. fishing and lost mine somewhere in Kansas. I had to use the above mentioned.
Remove the quick disconnect fittings from the HPOP, and take them to a local hydraulics shop, replace them with JIC fittings, and have some hoses made. just make sure the hoses have a burst strength of at least 6000 # (your stock HPOP works at up to 2900+ #s if it is in good condition) fittings and hoses should come in less than $125
KCM also has some hard line SS lines, but I am not sure the cost on them.
Originally Posted by Kwikkordead
Who is KCM?
http://members.***.net/kcmdieselperformance/ford.htm
Originally Posted by clux
KCM builds the stainless steel HPX, but I don't know about the feed lines.
These are 3/8" ID SS lines. KCM builds them.
