Help with rounded cop bolt!
Group,
I had a misfire on cylinder 7 and the cop bolt ( 7mm ) rounded. I have tried a smaller socket and vise grips do not seem to fit inthere to get at it. any help or advise would be very helpful. I was looking at the "Bolt out" kits from Sears but they seem to have size 6 and 8 but not 7. The truck is running really rough and I have to drive it due to my work and I'm starting to think that I am also loosing fuel economy as well. and I also notice a strong smell of sulfur. help!!
Drill off the head - take out a COP bolt that's easy to get out Find a drill bit slightly larger than the threads. Drill through the center of the head of the bolt until the head falls off. Remove the COP.
Then you might be able to get a vice-grip on what's left of it. The COP is so thick, you should have about 3/8" of stud sticking out of the hole. PB blaster, CRC penetrant, Gibbs, whatever, soak it.
If you have to, you might have to use an easy-out to get the rest of the bolt out.
[QUOTE=Bostonsound]Krewat,
Thank you, I might have to take that action but I am going to stop by Sears tonight and see if they have a bolt off set or a long set of vise-grips. QUOTE]
unless sears has started selling a better line of tool,I have never saw a set of vise-grips there woth throwing in the garbage
could it be a sears socket started your problem??
If that bolt is stuck well enough to round off the head, an EZ out will not be able to remove it. The LAST thing you want to do is use an EZ out on it. Shear an EZ out off inside that bolt and see how well you can drill that out without damaging the threads - NOT likely. Take it from a guy who had to drill out 12 sheared head bolt studs before.
I don't know how much room you have to work on this, but if you can get a small angle grinder or even a Dremel tool with a cut off wheel you can probably re-form the sides to the next smaller size and put a socket on it. Another very good solution if you have access to a welder is set a big nut on top of the bolt head and weld from the inside of the nut to the top of the bolt head. This gives you a very good head to wrench the bolt off and the high heat from the welder will usually stretch the bolt a bit and free it up enough to come out. Drilling should always be a last resort.
Dan
Dan
Thank you all for the great suggestions!!
Here is where I am so far.
1. Needle nose vise grips..No luck
2. Tried Bolt off set but the set did not seem to have the correct size Ugh!
3. Removed the next cop over for clearance, no help
4. Moved the fuel rail out of the way for even more room.
5. The affected cop moves from side to side but I'm starting to think that the bolt got crossed when installed ( Not by me! )
6. Spent over three hours on it last night and since I do not have a dremel or a compressor I had to put it all back together so I could got to work this morning still running rough Etc...
I am amazed that this simple job has turned so ugly!
I guess there's no way to tell if the COP is bad? If you know it is, then just cut the flange from the COP in-place, then put a regular pair of vice grips on it.
If you do braze something onto that screw, make sure you remove the fuel rail and seal the supply completely. Also, if you braze the scew I would think it would destroy the COP anyway.
