Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 Performance Ford F-150's
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 02-15-2008, 02:54 PM
youngssvt is starting off with a positive reputation.
plugs for lightning
04 lightning whats the best plug's to use im going 2 put #4 pulley
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 02-15-2008, 04:02 PM
irishammer is starting off with a positive reputation.
Try posting this in the Lightning forum...you will get better help there.
  #3 (permalink)
Old 02-15-2008, 05:57 PM
horsepuller's Avatar
horsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant futurehorsepuller has a brilliant future
Moved from '09 F150 forum.
Welcome and thanks for joining us at FTE!
__________________
Scott
FTE Moderator
  #4 (permalink)
Old 02-15-2008, 09:45 PM
Stewart_H's Avatar
I Have A Need 4 Speed
Stewart_H has a good reputation on FTE.Stewart_H has a good reputation on FTE.
NGK TR 6
Lotta guys running low boost on a stock block with those plugs, and a lot of guys running high boost on built blocks with those plugs.
They are very forgiving and hold up really well.
Stewart
__________________
1999 F150 Lightning
- Woodbine Motorsports built block
2000 PSD 4X4 Excursion
- John Wood tranny, DP-Tuner, AFE, MBRP 4", BDP 1.0, Overboost Annihilator, ITP Pre-Pump mod, Gauges from ITP, V & B code springs, Hellwig rear sway.
  #5 (permalink)
Old 02-17-2008, 03:35 PM
wd13's Avatar
wd13 is gaining momentum as a positive member of FTE.
+1. They're cheap too!
__________________
Built 2001 Lightning, 10.64 @ 127 Still a few stock parts!
Early 99 PSD, dp tuner, Banks intercooler, turbo housing and big head, AIS intake, 4" exhaust, zoodad, FPR shim, South Bend clutch, 8" lift on 36" PJ's
  #6 (permalink)
Old 02-17-2008, 04:25 PM
Silver Streak is gaining momentum as a positive member of FTE.
Ditto what the other guys said on the NGK's. The only drawback is that they are not an extended life material (platinum, iridium, etc.) and will require changing more often. That's not a big deal to some and it's a deal breaker to some. If I ran my truck hard a lot it would be worth a 2 hour plug change to have a friendly plug in there.
I run Densos in my truck and they work really well, but I'm on stock boost. They smoothed out the idle a little bit and the response feels a little more crisp.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #7 (permalink)
Old 02-18-2008, 12:12 AM
wd13's Avatar
Haha! Go built, I change my plugs about everytime I change the oil it seems like. I use the Denso's in it too!
__________________
  #8 (permalink)
Old 02-19-2008, 12:28 AM
i got the densos (it22) cost me $85 thats the most i have ever spent on plug's u got to pay to play lol
  #9 (permalink)
Old 02-19-2008, 08:53 AM
And these days that's cheap. It's not uncommon for an OE plug to be $25-30 each and some engines won't run right without them.
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
  #10 (permalink)
Old 02-24-2008, 10:19 AM
deebee53 is starting off with a positive reputation.
I run TR6's with my 4 lber and a Magnum Powers blower.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
