59 f100 clutch bleeding
Old 02-14-2008, 01:49 PM
19594x42000's Avatar
19594x42000
19594x42000 is offline
I replaced my clutch hose, which you guys were great in giving me advice. Now I can't seem to bleed the air out. Can I get some help on bleeding my line please!
Old 02-14-2008, 03:11 PM
sandhillmike's Avatar
sandhillmike
sandhillmike is offline
?? just like bleeding brakes
Old 02-14-2008, 09:03 PM
19594x42000
I lose pressure when I bleed them like the brake. I press then release the valve from the slave and end up losing pressure. I get more pressure when I tighten the slave cylinder up, take the top off the master cylinder and just pump it slow? I dont get it, I need air out, please help.
Old 02-14-2008, 09:17 PM
cmoritz's Avatar
cmoritz
cmoritz is offline
I've always had good luckwith this method..,
Find 12-16 inch long piece of vacume hose that fits over slave cylinder bleeder
find suitable plastic bottle with screw-on lid, drill hole in lid to o.d of vacume hose , add 6 oz brake fluid to bottle, insert tube into cap, submerge end of hose into brake fluid,
fill master cylinder, pump clutch pedal..until clean fluid fills bottle.
Old 02-15-2008, 07:15 AM
Walston's Avatar
Walston
Walston is offline
I did mine the same way.
ItsAFord55
12-27-2015 07:11 PM
beersy50
12-06-2015 12:41 PM
srumble
11-17-2007 06:36 PM
JustinGustafson
11-16-2006 01:42 PM
runner
03-15-2003 09:25 AM
Quick Reply: 59 f100 clutch bleeding
