Crewcab Only Thread.
#3301
<--- reading and comprehension skills must not be my strongest point. lol
Sorry everyone carry on.
#3302
#3303
Good luck
#3304
ok thanks , but too late i remove both in same time ....
they were find before.. i not paint the hinges so i see the place where the washer and bolt are but Nothing.. the door not fit correct like before....
so i thing mayby i have to do it in step like fist tight the 2 in the back first and other after or ...ect...
thanks
thanks
#3305
Here is "a way"
Place vehicle on level pavement
Bolt up door hinges loosely so the door can move
Slowly close the door you may have to pick it up and wiggle a bit
Using wedges etc set door space tolerances, up and down by readjusting the striker
Once you are happy with the placement use two magnetic levels
place them on the outside of the door perpendicular to each other
Make sure the bubbles are centered
Open the doors just enough to get to the hinges with a wrench
using milk crates etc. recreate the position until the bubbles are centered (PITA!!)
Once centered lock down bolts but do not torque or overly tighten
(Some people like to start here) Close the door, it will be a little off
use a protected levering device to push/slide/wiggle the door in place that last little bit
Carefully open the door and torque down the bolts
Not right loosen bolts slightly and reapply leverage
#3307
Bought our first Cewcab tonight!!!
73 F-350 CrewCab Special on a 78 reg cab lowboy frame.
Bought this tonight, Nice guy, turns out he bought it 2yrs ago 2miles from my house. Small world. Coming home baby!!!!! So it was a 73 pre-smog 2wd, clean title and non op woo hoo. on a reg lowboy frame. It will get cleaned and removed where it will get placed on a 78 supercab longwheel base frame and a short bed added.
This bad boys donating its frame and underpinnings to the 73 Crewcab.
So I am going to need the little race track trim between the doors! anyone? Anyone?
#3308
that should make a nice nice looking truck. But you're going to need to build a custom box as a short bed won't fit that wheel base.
#3310
#3313
we put all trucks side by side and looks as we are still going to have to shorten the Longbed from the SC by 6-8" to fit the CC. We knew we had to shorten the frame if we were going to do a SB SC. But now we are going to mount the CC onto it and use the one that the CC is on now which is a longbed RC and mount the 2wd SC SB onto it so the 2 keepers will be 4x4s.
#3315
