Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Illinois Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
  #1 (permalink)
Old 02-10-2008, 06:01 PM
brian ski brian ski is offline
Garage is empty, add now
brian ski is starting off with a positive reputation.
96 windstar P1408 P1464
I have a 96 windstar and have OBD2 codes P1408 and P1464. I,ve changed the injectors, changed the EGR , coil pack, cleaned intake manifold, checked all vacume lines and no leaks . I do have water in the oil , and am losing antifreeze but no leaks that I can see . It starts fine and runs fine for about 30 minutes then tries to die. Check engine flashes(is always on). Shut down and restart and runs as if nothing happened. Will continue like this until it can be shut down for at least a half hour. I thought I had it narrowed down to the PCM , that is until I saw a thread on this site with the same symtoms except no codes. they said it was a bad intake gasket. I've heard al kinds of stories about the head gaskets, 140.000 miles. any suggestions would be a big help, Thanks
  #2 (permalink)
Old 02-14-2008, 03:30 PM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.
if its got a 3.8 you probably got a blown head gasket thats where your anti freeze is going . they are / were JUNK motors . had a couple of 'em { the wife } and i'll never own anything ever again with that engine in it even if it is free . the last one kept flashing a couple of codes as it ran fine till it warmed up then went to hades , and overheated . throw it away and get something else . thats my .02 cents worth .
__________________
that's because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { don't } know especially to newcomers. were on a mission to impress you and make you believe we are all knowing ! P.A.D.D = project attention deficit disorder . everyone on here has it , and is an enabler !!!! so enter at your own risk !!!!!!!!!!! if you don't have 2 or 3 broken fords / projects , then you just ain't right !!!!!!!!!!!!!!!!
  #3 (permalink)
Old 11-11-2008, 08:30 PM
keating6614 keating6614 is offline
keating6614 is starting off with a positive reputation.
96 Winstar CEL on problems
I just replied to someone else, bas12441, on a similar problem. I do not want to repeat the process but it was my intake. Running good now. Check it out.
This thread is located at:
http://www.ford-trucks.com/forums/sh...1&goto=newpost
Tags
2003, 96, code, codes, coil, ford, obd, obd2, p1408, p1464, pack, problem, service, windstar, winstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
