Turbo problem I think
95 PSD.
Not sure I am describing this right but here goes.
Last year started the truck and it had no power. I would describe it as if the exhaust was plugged up. Turned it off and started it up again. All has been good since. Recentley I have noticed when I start it up and take off there is a momont where it feels the same way and then it goes away. Does this thing have a waste gate (or whatever it is called) in the turbo that is not opening as it should or is this normal. If not what can I do? I'm driving to CO. with the boys over spring break and am kinda concerned about it.
Thanks
Thanks
The EBPV is controlled by oil pressure. It turns off when the oil temp reaches a certain temperature. I can't remember the exact temp but I think its somewhere around 120?
Thus, it takes a long time to get your oil temp that high let alone up to operating temperature.
Also, the valve will open once you hit a certain rpm and will close again once it goes below that desired rpm/back pressure.
Most people on here have them unplugged besides they stick or they become annoying. Some even have them rigged up for an exhaust break.
