Gang; here's the RIGHT part number....
I hope the part number I gave you earlier helped you get the current part number. Glad you were able to get one.
Dustin Siebert
mrlaserboy(No Email Addresses In Posts!)
Registry: http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=201
Home Page: http://www.superford.org/users/ylobronc/index.html
'88 Bronco XLT 302EFI/AOD/BW1356/44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56/6" Superlift/2" BL/35's-street/38.5's-trails
2 BIG BRONCOS 4X4 CLUB - GREAT LAKES CHAPTER http://www.2bigbroncos.org
Dustin Siebert
Mrlaserboy,
Thanks for the number. Actually you had pointed out it was out-of-date, so all I did was walk in with oil filter in hand and ask for the thigamabob that the oil filter screwed onto and the boy at the counter looked it up with no problem.
Cheers...and thanks for the great pix....it should be about 2 weeks and this project will be over (whew!!)....all my pictures of Harrison will then be posted at www.beedzncomputers.com.
LaptopGeek
LaptopGeek
C9AZ-6890-A ---- UPDATE ----
This number will get you the same thing I am looking to replace!! Use THIS number -> F1AZ-6850-B. This part will allow you to screw the oil filter directly onto the block!! It has threads on the block side and threads on the filter side - use a HUGE hex wrench or a bolt and double locknut to screw the adapter in. I hope this helps somebody...
The LaptopGeek -----
1974 White F100 Custom Fleetside
460 bored .040 over & C-6 automatic 2WD
Lunati cam, L&L Headers / mounts
Holley Avenger 770CFM & Edlebrock RPM
Plush black leather 40-20-40 bench seat
38 gallon JC Whitney fuel tank
laptopgeek
07-30-2001 02:10 PM
laptopgeek
13
07-10-2001 01:51 AM
laptopgeek
06-27-2001 07:59 AM
